smartfueb_march_gmail_com@instance-1-ubuntu16:/home/smartfueb_march/openhab-google-assistant/functions$ gcloud beta functions deploy openhabGoogleAssistant --stage-bucket smart_test1 --trigger-http
Deploying function (may take a while - up to 2 minutes)...failed.
ERROR: (gcloud.beta.functions.deploy) OperationError: code=3, message=Function failed on loading user code. Error message: Code in file index.js can't be loaded.
Is there a syntax error in your code?
Detailed stack trace: TypeError: smarthome is not a function
at Object.<anonymous> (/user_code/openhab.js:23:13)
at Module._compile (module.js:577:32)
at Object.Module._extensions..js (module.js:586:10)
at Module.load (module.js:494:32)
at tryModuleLoad (module.js:453:12)
at Function.Module._load (module.js:445:3)
at Module.require (module.js:504:17)
at require (internal/module.js:20:19)
at Object.<anonymous> (/user_code/index.js:18:17)
when can we expect this implementation to openHAB, even I am trying to implement the report state but I am getting 404 error saying that Requested entity was not found in docs they are saying it is because of agentUserId, I am not getting what I am missing.. please help me out on this.
