I’m having some trouble with IDE setup. After a fresh install using Eclipse Installer and the openHAB 2 Add-ons project, I’m getting errors all over (over 14000), and the following errors in the Target Platform, which I think may be the cause:
I am trying to install the openHAB2 IDE using Eclipse Installer and the instructions found here: http://docs.openhab.org/developers/development/ide.html. However, I get the exact same error as @fa2k and cannot find a way around the problem. Since the Eclipse Installer selects Eclipse Neon for installation, it should work with that version, right?
I’m answering this myself, since I have solved the problem now. Well, “solved” may not be the best word. I ended up reinstalling Ubuntu completely and then the Eclipse Installer and the Target Definition magically started working…
