Hello all,
i extented the jeelink binding, that it will also recognize the EMT7110 energy meter.
So far it works i can read the data in the item, but the thing ist all the time offline.
in the openhab console i found the follow error:
22:58:36.162 [WARN ] [nfig.discovery.DiscoveryResultBuilder] - Representation property 'id' of discovery result for thing 'jeelink:emt7110:7c86e4e0f3:8496' is missing in properties map. It has to be fixed by the bindings developer.
at java.base/java.lang.Thread.getStackTrace(Thread.java:1619)
at org.openhab.core.config.discovery.DiscoveryResultBuilder.getStackTrace(DiscoveryResultBuilder.java:176)
at org.openhab.core.config.discovery.DiscoveryResultBuilder.build(DiscoveryResultBuilder.java:155)
at org.openhab.binding.jeelink.internal.discovery.SensorDiscoveryService.handleReading(SensorDiscoveryService.java:131)
at org.openhab.binding.jeelink.internal.JeeLinkHandler.handleInput(JeeLinkHandler.java:237)
at org.openhab.binding.jeelink.internal.connection.AbstractJeeLinkConnection.propagateLine(AbstractJeeLinkConnection.java:69)
at org.openhab.binding.jeelink.internal.connection.JeeLinkSerialConnection$1.serialEvent(JeeLinkSerialConnection.java:84)
at org.openhab.core.io.transport.serial.rxtx.RxTxSerialPort$1.serialEvent(RxTxSerialPort.java:82)
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:834)
at gnu.io.RXTXPort.eventLoop(Native Method)
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:108)
Do someone have a hint, what i did wrong? How is the state of a thing working? And what is this error with the id?
thanks
PS: i will create a MergeRequest, when everything works well.
