i have created a rule to set a timer with reschedule function, but as ist seem something is not working with the reschedule function.
16:07:39 there was a reschedule event but timer expired 16:09:21
Thomas
rule "Kueche an"
Item Bewegung_EG_Kueche changed
if(Bewegung_EG_Kueche.state==ON) {
logInfo("Kueche","an")
sendCommand(Light_EG_Kueche_Decke,ON)
sendCommand(Light_EG_Kueche_Table,ON)
if(Kueche_timer===null) {
logInfo("Kueche","Timer an")
// first ON command, so create a Kueche_timer to turn the light off again
Kueche_timer = createTimer(now.plusSeconds(600)) [|
sendCommand(Light_EG_Kueche_Decke,OFF)
sendCommand(Light_EG_Kueche_Table,OFF)
Kueche_timer = null
logInfo("Kueche Timer","aus")
} else {
// subsequent ON command, so reschedule the existing Kueche_timer
Kueche_timer.reschedule(now.plusSeconds(600))
logInfo("Kueche retrigger","+600 s")
here the log
2020-07-17 16:07:39.330 [INFO ] [clipse.smarthome.model.script.Kueche] - an
2020-07-17 16:07:39.330 [INFO ] [rthome.model.script.Kueche retrigger] - +600 s
2020-07-17 16:07:39.331 [ome.event.ItemCommandEvent] - Item 'Light_EG_Kueche_Decke' received command ON
2020-07-17 16:07:39.334 [ome.event.ItemCommandEvent] - Item 'Light_EG_Kueche_Table' received command ON
2020-07-17 16:08:10.536 [vent.ItemStateChangedEvent] - Bewegung_EG_Kueche changed from ON to OFF
2020-07-17 16:09:14.950 [vent.ItemStateChangedEvent] - Bewegung_EG_Kueche changed from OFF to ON
2020-07-17 16:09:14.950 [INFO ] [clipse.smarthome.model.script.Kueche] - an
2020-07-17 16:09:14.951 [INFO ] [rthome.model.script.Kueche retrigger] - +600 s
2020-07-17 16:09:14.953 [ome.event.ItemCommandEvent] - Item 'Light_EG_Kueche_Decke' received command ON
2020-07-17 16:09:14.955 [ome.event.ItemCommandEvent] - Item 'Light_EG_Kueche_Table' received command ON
2020-07-17 16:09:21.601 [INFO ] [.smarthome.model.script.Kueche Timer] - aus
2020-07-17 16:09:21.603 [ome.event.ItemCommandEvent] - Item 'Light_EG_Kueche_Decke' received command OFF
2020-07-17 16:09:21.606 [ome.event.ItemCommandEvent] - Item 'Light_EG_Kueche_Table' received command OFF
2020-07-17 16:09:21.762 [vent.ItemStateChangedEvent] - Light_EG_Kueche_Decke changed from ON to OFF
2020-07-17 16:09:21.873 [vent.ItemStateChangedEvent] - Light_EG_Kueche_Table changed from ON to OFF
2020-07-17 16:09:45.414 [vent.ItemStateChangedEvent] - Bewegung_EG_Kueche changed from ON to OFF
2020-07-17 16:14:37.439 [vent.ItemStateChangedEvent] - Bewegung_EG_Kueche changed from OFF to ON
