Hey I try to create a rule that let me use my shelly I4 buttons with different click events and for dimming while pressed.
This is the error when pressing my thing’s button:
21:02:44.072 [WARN ] [core.internal.scheduler.SchedulerImpl] - Scheduled job 'org.openhab.automation.script.ui.ShellyTestMultiPressHoldPatternRule.timeout.2' failed and stopped
org.graalvm.polyglot.PolyglotException: ReferenceError: "event" is not defined
at <js>.timerEnd(<eval>:100) ~[?:?]
at <js>.:=>(<eval>:135) ~[?:?]
at com.oracle.truffle.polyglot.PolyglotFunctionProxyHandler.invoke(PolyglotFunctionProxyHandler.java:154) ~[bundleFile:?]
at com.sun.proxy.$Proxy214.run(Unknown Source) ~[?:?]
at org.openhab.automation.jsscripting.internal.threading.ThreadsafeTimers.lambda$1(ThreadsafeTimers.java:121) ~[bundleFile:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$12(SchedulerImpl.java:191) ~[?:?]
at org.openhab.core.internal.scheduler.SchedulerImpl.lambda$1(SchedulerImpl.java:88) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
21:02:48.137 [WARN ] [se.californium.scandium.DTLSConnector] - Shutdown DTLS connector on [0.0.0.0/0.0.0.0:54795] executor not terminated in time!
This is my rule:
configuration: {}
triggers:
- id: "2"
configuration:
itemName: shellyplusi4a8032ab1101c__19216817863_EingangTaste_1
conditions: []
actions:
- inputs: {}
configuration:
type: application/javascript;version=ECMAScript-2021
script: >-
console.log("script called");
// INIT
var dimItem = items.getItem('WohnzimmerTischlampe_Helligkeit'); // set your dim Item here.
var now = time.ZonedDateTime.now();
var cacheId = "TestBtnMultiPressPattern5742"
var storage = cache.private.get(cacheId, () => ({
'timerId' : null,
'count' : 0,
'dimUp' : false,
'dimTimerId' : 'TestBtnMultiPressPattern8956DimTimerId',
'dimTimer' : null,
var delay = 500;
function cancelTimer (logMsg) {
console.log(logMsg);
if (storage.timerId === undefined) {
console.log("timer === undefined");
} else {
clearTimeout(storage.timerId);
cache.private.remove(cacheId);
console.log("timer canceled");
Attention: https://github.com/rkoshak/openhab-rules-tools#function-generators
function clickOne() {
cancelTimer("Called function number " + storage.count);
function clickTwo() {
function clickThree() {
function clickFour() {
function dimFunction() {
// Set dim direction
if (dimItem.state == 100) {
storage.dimUp = false;
cache.private.put(cacheId, storage);
} else if (dimItem.state == 0) {
storage.dimUp = true;
// Dimming step
if (storage.dimUp == true){
dimItem.sendCommand(INCREASE);
} else {
dimItem.sendCommand(DECREASE);
// reschedule dimmer to loop
storage.dimTimer.reschedule(now.plusSeconds(1));
function timerEnd(n) {
console.log("timerEnd triggered, state=" + event.oldItemState /*+ ", oldState=" + event.ItemState.toString()*/)
if (event.oldItemState.toString() == "OFF") { // Short press cases
switch (n){
case 1:
clickOne();
break;
case 2:
clickTwo();
break;
case 3:
clickThree();
break;
case 4:
clickFour();
break;
default:
cancelTimer("Clicked " + storage.count + " times.");
} else { // hold cases
cancelTimer("Btn Timer stopped, hold action.");
// set dim timer
if (storage.dimTimer === null) {
storage.dimTimer = actions.ScriptExecution.createTimer(storage.dimTimerId, now, dimFunction);
if (event.itemState.toString() =="ON") { // only check button down state
if (storage.timerId !== null)
storage.count ++
console.log("Click number " + storage.count + " detected.")
storage.timerId = setTimeout( () => timerEnd(storage.count), delay);
type: script.ScriptAction
Platform information:
- Hardware: CPUArchitecture/RAM/storage RPI4 x64 8GB
- OS: Ubuntu 20.04.5 LTS
- Java Runtime Environment: openjdk 11.0.17 2022-10-18 OpenJDK Runtime Environment (build 11.0.17+8-post-Ubuntu-1ubuntu220.04)
- openHAB version: 3.4.2
