I’m looking for a solution/ tutorial to reset my openhabian from ‘outside’, e.g. on travel (I have a secure connection via my KNX installation). I’ve noticed that my instance is from time to time lagging and stops recording data points in influxdb … caused whatever reason. A reset helps, even its not solving the root cause. Within the same NW at home I can reset via terminal connection via ssh but not from outside - but from outside I can access secured openhab web frontend.
Is there any ‘button’ or value, routine that can trigger a reset of the openhabian instance?
Regards
René
