OS: OpenHAB Raspbian based provided image, openhabianpi-raspbian-201804031720-gitdba76f6-crc9e93c3eb
openHAB version: 2
Issue of the topic: I cannot get my exec binding to work
home.sitemap:
sitemap home label="My home controls"
Frame label="Informations" {
Text item=Date
Frame label="Controls" {
Switch item=Main_Light icon="light"
Main_Light.item
Switch Main_Light "My Main Light"
Switch mainlight {channel="exec:command:mainlight:run"}
// Arguments to be placed for '%2$s' in command line
String mainlight_Args {channel="exec:command:mainlight:input"}
// Output of command line execution
String mainlight_out {channel="exec:command:mainlight:output"}
Main_Light.things:
Thing exec:command:mainlight [ command="/usr/bin/lights %2$s", interval=0, autorun=false ]
Main_Light.rules
rule "Your Execution"
Item Main_Light changed
if(Main_Light.state == ON){
mainlight_Args.sendCommand("on")
}else{
mainlight_Args.sendCommand("off")
// wait for the command to complete
// State will be NULL if not used before or ON while command is executed
while(mainlight.state != OFF){
Thread::sleep(500)
// Trigger execution
mainlight.sendCommand(ON)
// Logging of command line result
logInfo("Your command exec", "Result:" + mainlight_out.state )
// If the returned string is just a number it can be parsed
// If not a regex or another transformation can be used
// YourNumber.postUpdate(
// (Integer::parseInt(mainlight_out.state.toString) as Number )
And let not forget the /usr/bin/lights script:
#!/bin/bash
if [ $1 == on ]; then
sudo send_cmd "B0 91 4D BC C1 01 CA" && sudo send_cmd "B0 91 4D BC C1 01 CA" && sudo send_cmd "B0 91 4D BC C1 01 CA"
echo Light ON
elif [ $1 == off ]; then
sudo send_cmd "B0 91 4D BC C1 02 CA" && sudo send_cmd "B0 91 4D BC C1 02 CA" && sudo send_cmd "B0 91 4D BC C1 02 CA"
echo Light OFF
else
echo Please send a valid command
fi
As you can see, I used the exemple available on this page: Exec - Bindings | openHAB , but no matter what I do it doesn’t seem to execute anything, the command work in the linux CLI, but not via my switch on OpenHAB page.
2019-05-31 06:16:06.069 [vent.ItemStateChangedEvent] - Main_Light changed from ON to OFF
2019-05-31 12:33:58.374 [ome.event.ItemCommandEvent] - Item 'Main_Light' received command ON
2019-05-31 12:33:58.400 [vent.ItemStateChangedEvent] - Main_Light changed from OFF to ON
2019-05-31 12:34:03.451 [ome.event.ItemCommandEvent] - Item 'Main_Light' received command OFF
2019-05-31 12:34:03.468 [vent.ItemStateChangedEvent] - Main_Light changed from ON to OFF
As for permission, everyone in the sudo group and openhab is allowed to launch send_cmd as root, as my sudoers file contain
I added loginfo() at the beginning of the then statement
logInfo()
And here the change in the logs:
2019-05-31 14:43:11.434 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'Main_Light.rules'
2019-05-31 14:43:11.880 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': An error occurred during the script execution: null
2019-05-31 14:43:11.882 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': An error occurred during the script execution: null
2019-05-31 14:43:11.884 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': An error occurred during the script execution: null
2019-05-31 14:43:11.885 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': An error occurred during the script execution: null
2019-05-31 14:43:11.889 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.890 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.893 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.894 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.895 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.897 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.900 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.903 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.905 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.908 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.909 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.910 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.912 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.915 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.917 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.919 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.920 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.913 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.924 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:11.926 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': Script interpreter couldn't be obtain
2019-05-31 14:43:33.504 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2019-05-31 14:43:33.510 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Date' for widget org.eclipse.smarthome.model.sitemap.Text
2019-05-31 14:43:33.515 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Date' for widget org.eclipse.smarthome.model.sitemap.Text
2019-05-31 14:43:33.519 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Date' for widget org.eclipse.smarthome.model.sitemap.Text
2019-05-31 14:43:35.445 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': An error occurred during the script execution: index=0, size=0
2019-05-31 14:43:45.796 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': An error occurred during the script execution: index=0, size=0
2019-05-31 14:44:33.368 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': An error occurred during the script execution: index=0, size=0
2019-05-31 14:44:34.778 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': An error occurred during the script execution: index=0, size=0
2019-05-31 14:44:36.046 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': An error occurred during the script execution: index=0, size=0
2019-05-31 14:44:37.564 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Your Execution': An error occurred during the script execution: index=0, size=0
events.log:
2019-05-31 14:43:34.935 [ome.event.ItemCommandEvent] - Item 'Main_Light' received command ON
2019-05-31 14:43:34.964 [vent.ItemStateChangedEvent] - Main_Light changed from OFF to ON
2019-05-31 14:43:45.767 [ome.event.ItemCommandEvent] - Item 'Main_Light' received command OFF
2019-05-31 14:43:45.780 [vent.ItemStateChangedEvent] - Main_Light changed from ON to OFF
2019-05-31 14:44:33.326 [ome.event.ItemCommandEvent] - Item 'Main_Light' received command ON
2019-05-31 14:44:33.361 [vent.ItemStateChangedEvent] - Main_Light changed from OFF to ON
2019-05-31 14:44:34.739 [ome.event.ItemCommandEvent] - Item 'Main_Light' received command OFF
2019-05-31 14:44:34.766 [vent.ItemStateChangedEvent] - Main_Light changed from ON to OFF
2019-05-31 14:44:36.013 [ome.event.ItemCommandEvent] - Item 'Main_Light' received command ON
2019-05-31 14:44:36.032 [vent.ItemStateChangedEvent] - Main_Light changed from OFF to ON
2019-05-31 14:44:37.531 [ome.event.ItemCommandEvent] - Item 'Main_Light' received command OFF
2019-05-31 14:44:37.558 [vent.ItemStateChangedEvent] - Main_Light changed from ON to OFF
So there definitively something wrong, but no idea what?
I should also mention that I did install the regex transformation.
PS: I know date is invalid, I haven’t had time to look to fix it yet and just kept the example, it don’t matter for now (Except if that what break my light switch?)
Okay, logInfo() was just a shorthand example. In reality, just like the other place in your rule that uses logInfo, you need to give it two parameters.
logInfo(“mytest”, “here I am”)
Anyway, the error of it blowing up because of missing parameters does tell you that the rule is triggering.
Now add more logInfo with different messages so that you can see how far through the rule it is getting.
Thread::sleep(500)
was the issue, once I commented it, it started working!
