hi, i just got in touch with this platform, i was amazed by its granular and complete organization. it remains a bit difficult for me to configure things.
as a first test I know trying to configure a sonoff 4ch I managed to create the switches, and they work β¦ but the status of the same does not update automatically. I tried a few adjustments found around the forum, but with negative effect.
I will certainly make a mistake in doing something, but I have run out of attempts and I can no longer go on.
i am operating on OH3 with local operhabian server and cloud.
Thanks for your help
Please show your full openHAB and Tasmota configuration for this setup.
UID: mqtt:topic:d2cfc207ce:6506d74b4d
label: Sonoff4chGar
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:d2cfc207ce
channels:
- id: Sonoff4chGar
channelTypeUID: mqtt:switch
label: Basculante
description: ββ
configuration:
commandTopic: cmnd/Sonoff4chGar/power1
postCommand: false
stateTopic: stat/Sonoff4chGar/power1
off: β0β
on: β1β - id: Luce_Scala
label: Luce Scala
description: ββ
configuration:
commandTopic: cmnd/Sonoff4chGar/power2
stateTopic: stat/Sonoff4chGar/power2
off: β0β
on: β1β - id: Luce_Garage
label: Luce Garage
description: ββ
configuration:
commandTopic: cmnd/Sonoff4chGar/power3
stateTopic: stat/Sonoff4chGar/power3
off: β0β
on: β1β - id: luce_esterna
label: Luce Esterna
description: ββ
configuration:
commandTopic: cmnd/Sonoff4chGar/power4
stateTopic: stat/Sonoff4chGar/power4
off: β0β
on: β1β
hope it can help
You might try using values βONβ and βOFFβ instead of β1β and β0β. Those are the values used by my Sonoff-SV with Tasmota.
I have already tried but nothing changes
Iβm using OH 2.5 with text configs and some Tasmota 11.x.x devices, but I think you have the wrong stateTopic, which should be:
stateTopic: stat/Sonoff4chGar/RESULT
You then need a JSON transformation to get the value of RESULT. Iβm not yet familiar with OH 3.X, but the JSON transformation from my text configs is:
transformationPattern="JSONPATH:$.POWER#"
In your case, replace the # above with the channel number (1 through 4) as appropriate.
I also think you need on and off defined as follows:
off="OFF"
on="ON"
Hope this helps!
When I have MQTT issues, I find MQTT Explorer very useful.
In commandTopic and stateTopic POWER should be uppercase, see my config.
UID: mqtt:topic:d0a861377f:Tasmota_Garage
label: Tasmota Garage
configuration:
payloadNotAvailable: Offline
availabilityTopic: tele/garage/LWT
payloadAvailable: Online
bridgeUID: mqtt:broker:d0a861377f
channels:
- id: Garage_1
label: Garage 1
description: ""
configuration:
commandTopic: cmnd/garage/POWER1
stateTopic: stat/garage/POWER1
- id: Garage_2
label: Garage 2
description: ""
configuration:
commandTopic: cmnd/garage/POWER2
stateTopic: stat/garage/POWER2
- id: Garage_3
label: Garage 3
description: ""
configuration:
commandTopic: cmnd/garage/POWER3
stateTopic: stat/garage/POWER3
- id: Garage_4
label: Garage 4
description: ""
configuration:
commandTopic: cmnd/garage/POWER4
stateTopic: stat/garage/POWER4
- id: IP_Address
channelTypeUID: mqtt:string
label: IP Address
description: ""
configuration:
stateTopic: stat/garage/STATUS5
transformationPattern: JSONPATH:$.StatusNET.IPAddress
uppercaseβ¦
everything ok thanks 1000
