[Resolved]Use tshark to detect unknown wifi devices around
I used tshark (wireshark) to detect any unknown wifi devices which are around. It worked basically fine. However, there are some problems I have to start/stop tshark in order to process the data. I am looking for a better way to improve it so I do not have to stop tshark to process the data. Keeping it running in the background all the time.
My current implementation :
while true
do
tshark -nn -i wlan0 -I -l subtype probereq | grep --line-buffered -v “32:8a:ae:bd:5a:8c|60:a4:4c:d1:f4:f8(here is a long list of known wifi devices)” > dat.txt &
(only interested in probe request frames)
sleep 30
killall tshark
DEVICES=awk '{print $3 }' dat.txt (get mac address only)
echo 0 > dat.txt (clear the data for next run)
if [[ $DEVICES = : ]]
curl --max-time 2 --connect-timeout 2 --header “Content-Type: text/plain” --request PUT --data “ON” http://127.0.0.1:8080/rest/items/mobile_mac_unknown/state
echo “FOUND UNKNOWN DEVICES”
else
curl --max-time 2 --connect-timeout 2 --header “Content-Type: text/plain” --request PUT --data “OFF” http://127.0.0.1:8080/rest/items/mobile_mac_unknown/state
echo “NOT FOUND UNKNOWN DEVICES”
fi
done
If I do not kill tshark, the dat.txt will be accessed by two processes. It seems not to work reliably.
Any thoughts how to work around this?
I found this answer after a bit research. A python script would resolve it. Attached the code here. Maybe it is useful for others.
This example is to find an known device. It is easy to expand to unkown devices as well. Of course there are still improvement.
tshark -nn -i wlan0 -I subtype probereq | python ta.py
==ta.py==
#!/usr/bin/python
import requests
import sys
import os
s4 = “cc:3a:61:xx:xx:xx”
while True:
line = sys.stdin.readline()
if not line:
break
#sys.stdout.write(line)
if s4 in line:
r = requests.put(‘http://127.0.0.1:8080/rest/items/mobile_mac_s4/state’,data=“ON”)
print “FOUND s4”
else:
r = requests.put(‘http://127.0.0.1:8080/rest/items/mobile_mac_s4/state’,data=“OFF”)
print “NOT FOUND s4”
On which hardware are you running tshark? and which linux distribution?
Thank you!
I was using Ubuntu 12/14
