I created a Powershell (yes I mainly work on Windows…) which creates my things via json files. This is working fine as long as there are no Channels defined, and more specific when there are no [objects] in the config.
The strange thing is when I paste the same json text in the API explorer, it’s working fine.
When I remove the Configuration part in the channels object, it’s working, but offcourse without my config.
This is the error I receive:
"{\"error\":{\"message\":\"java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 24 column 25 path $.channels[0].configuration\",\"http-code\":500,\"exception\":{\"class\":\"com.google.gson.JsonSyntaxException\",\"message\":\"java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 24 column 25 path $.channels[0].configuration\",\"localized-message\":\"java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 24 column 25 path $.channels[0].configuration\",\"cause\":\"java.lang.IllegalStateException\"}}}"
"label": "SNMP Synology",
"configuration": {
"retries": 2,
"hostname": "192.168.0.0",
"protocol": "v2c",
"port": 161,
"refresh": 60,
"community": "public",
"timeout": 1500
"properties": [],
"UID": "snmp:target:synonas",
"thingTypeUID": "snmp:target",
"channels": [
"uid": "snmp:target:synonas:systemStatus",
"id": "systemStatus",
"channelTypeUID": "snmp:number",
"itemType": "Number",
"kind": "STATE",
"label": "System State",
"description": "",
"configuration": {
"oid": ".1.3.6.1.2.1.25.3.2.1.3.196608"
"location": "basement"
