REST/HTTP call
I have OH2 on my local box and able to setup simple actions.
I am trying to make a REST call to some external system. I checked Yahoo weather and i am able to make it work. But i am trying to understand how OH2 allows to make external REST calls.
Option1 : I was thinking that http binding should allow me to do it directly. But i do not see anything for my http binding even i have Bindings.
Option2: I was thinking that REST call should allow me to make external call directly in OH2 but i see only REST API Docs in bindings.
Not sure how to make simple REST call to external system and capture the results.
Any help is appreciated.
Have a look into the following post to see an example of a more complex request from a OH rule:
For a simple call with get parameters sendHttpGetRequest(httpRequest) should be enough:
    val yahooWeatherLocationId = "782306"
    val httpRequest = "https://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20weather.forecast%20where%20woeid%3D" + yahooWeatherLocationId + "&format=json&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys"
    val String yahooWeatherJSON = sendHttpGetRequest(httpRequest)
with kind regards,
Patrik
Thanks for the example. As mentioned i am new to OH2
Here are the steps i might need to do to connect to external REST service.
  1. Declare Items
  2. create Rule - Make a call to service and convert Json response to Objects. Update Items
  3. sitemap link.
is my understanding correct..?
yep - that’s right; let me/us know if you need help with one of the steps.
