Since an upgrade from 1.6.0 to 1.7.1 i can’t get the rest interface to work.
The only error i can find in the log is:
22:20:25.010 [ERROR] [sphere.cpr.AtmosphereFramework:906 ] - Failed to initialize Atmosphere Framework
java.lang.TypeNotPresentException: Type javax.xml.bind.JAXBContext not present
at sun.reflect.generics.factory.CoreReflectionFactory.makeNamedType(CoreReflectionFactory.java:117) ~[na:na]
at sun.reflect.generics.visitor.Reifier.visitClassTypeSignature(Reifier.java:125) ~[na:na]
at sun.reflect.generics.tree.ClassTypeSignature.accept(ClassTypeSignature.java:49) ~[na:na]
at sun.reflect.generics.visitor.Reifier.reifyTypeArguments(Reifier.java:68) ~[na:na]
at sun.reflect.generics.visitor.Reifier.visitClassTypeSignature(Reifier.java:138) ~[na:na]
at sun.reflect.generics.repository.ClassRepository.computeSuperInterfaces(ClassRepository.java:117) ~[na:na]
...[[[ cut some lines here ]]] ....
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70) [org.eclipse.equinox.util_1.0.400.v20120917-192807.jar:na]
Caused by: java.lang.ClassNotFoundException: javax.xml.bind.JAXBContext
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:475) ~[org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421) ~[org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412) ~[org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107) ~[org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at java.lang.ClassLoader.loadClass(ClassLoader.java:356) ~[na:na]
at java.lang.Class.forName0(Native Method) ~[na:na]
at java.lang.Class.forName(Class.java:371) ~[na:na]
at sun.reflect.generics.factory.CoreReflectionFactory.makeNamedType(CoreReflectionFactory.java:114) ~[na:na]
... 66 common frames omitted
Running Debian
java -version
java version “1.9.0-ea”
Java™ SE Runtime Environment (build 1.9.0-ea-b78)
Java HotSpot™ 64-Bit Server VM (build 1.9.0-ea-b78, mixed mode)
