KiffKeff
(Kevin M.)
December 25, 2023, 9:33am
1
Hello everyone,
I need your help. I want to change my openhab from my RASP to docker. Everything worked fine except the backup.
I have copied the directories from the backup zip into the respective folders. But without success.
I have also tried to start openhab-config without success.
I need a hint.
Wolfgang_S
(Wolfgang_S)
December 25, 2023, 10:29am
2
What does without success mean ?
Errors/warnings?
Please provide more details.
the UI-transfer should be successfull, if you use the functions backup to zip an restore from zip.
Same Version?
Greetings
Maybe wrong ownership (check user/group id of the openhab user inside the container and change ownership of all files and folders. Double check correct ownership
KiffKeff
(Kevin M.)
December 27, 2023, 9:02pm
5
Hi Wolfgang_S,
i fixed the problem.
I have copied the directories from the backup zip into the respective folders. Then i restart the container and it works.
