If i restarted Openhab, the state could not restore with this error in the log:
2018-01-07 19:38:55.164 [WARN ] [rm.AbstractFileTransformationService] - Could not transform '1.0' with the file 'lueftung.map' : Target value not found in map for '1.0'
My lueftung.map:
0 = Sommer
1 = Winter
2 = Immer an
3 = AUS
I don’t know, why 1.0 and not 1 is saved in InfluxDB.
I suspect that InfluxDB doesn’t have the concept of intergers or the way OH saves data to InfluxDB it saves everything as floating point numbers.
This comment I found on an InfluxDB issue indicates that may be the case:
Because of this and a host of other issues, we’re considering ditching int64 as a user data type entirely and just making every number in the system (other than timestamps) a float64. There should be an explicit decision one way or the other with 0.9.3 in mid-August.
Ok, thanks. I was not sure if i missed something. My intention was to use only one persistence (use InfluxDB with Grafana), so i’ve tried it with InfluxDB.
