Restrict access to OH2 for particular IP address / deactivation of HTTP
Hi all,
in the official OH documentation it is referred to restricting access for particular source IP addresses:
https://www.openhab.org/docs/installation/security.html#authentication-and-access-control
I’d like to restrict access for an IP range or at least some single entries.
I know that none of this syntax work:
OPENHAB_HTTP_ADDRESS=127.0.0.1, 192.168.0.1, 192.168.0.22
neither
OPENHAB_HTTP_ADDRESS=127.0.0.1,192.168.0.1,192.168.0.22
nor
OPENHAB_HTTP_ADDRESS=192.168.0.1
OPENHAB_HTTP_ADDRESS=192.168.0.22
Is there an option at all to configure it?
In addition can it be configured that OH service is not listening to HTTP but only on HTTPS?
Regards,
becken
As far as I can tell, you can only specify one address.
For HTTP vs. HTTPS, you might have to proxy through nginx.
I suggest xternal firewall. Under linux iptables and ip6tables does the job. You can sort the rules with destination ports.
I wouldn’t even be sure it works at all. It was a feature in OHv1 that was dropped in v2, and there recently were attempts to introduce that back into 2.4, but those failed and were removed. I’m not 100% sure if that “one address” was left in or if it’s a docs bug.
What you can and should do for the time being is to deploy a reverse proxy like nginx and do the authentication there (based on IPs and/or user). It can also do HTTPS.
A preconfigured nginx is part of openHABian.
