I love the feature to Return if someone is calling on the Phone via the AndroidApp to OpenHAB. I think it could be even better if there was a second Item which holds the Caller ID or the Name linked to the Caller ID. As a consequence it would be possible to have multiple behaviours depending on the caller.
I didnt know where to post this feature request (maybe github?) so I posted it here.
If I enable the Feature “Return Callerstatus to Openhab” it needs the Permission already. So it has the needed permission. Its just a matter of sending the number/string to the Server
This would require the READ_CALL_LOG permission. It’s not allowed to use this permission except for default SMS or phone apps.
There are a few other exceptions listed here, but none really matches the openHAB app.
I think you can do this with Tasker. The Android app has pretty good integration with Tasker and I believe that Tasker has the right permissions. There are at least Caller Name and Caller Number variables which appear to get populated when a call comes in. You can create a Task that triggers when the phone rings and send the value of the Caller Name/Caller Number variable to an OH Item using the OH Plugin in Tasker.
