I am using openhab 2.4.1 on a RPi3, and i get the following message in the “events.log” file while using the RFLink binding ( https://github.com/cyrilcc/org.openhab.binding.rflink ):
'rflink:bridge:usb0' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
This is the content of my “openhab.log” file after restarting openhab2 (and having DEBUG enabled for rflink addon: log:set DEBUG org.openhab.binding.rflink):
2019-12-18 10:08:49.598 [DEBUG] [org.openhab.binding.rflink ] - BundleEvent [unknown:512] - org.openhab.binding.rflink
2019-12-18 10:08:49.674 [DEBUG] [org.openhab.binding.rflink ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=120, service.bundleid=198, service.scope=bundle, component.name=org.openhab.binding.rflink.internal.RfLinkHandlerFactory, component.id=12} - org.openhab.binding.rflink
2019-12-18 10:08:49.685 [DEBUG] [org.openhab.binding.rflink ] - BundleEvent STARTING - org.openhab.binding.rflink
2019-12-18 10:08:49.689 [DEBUG] [org.openhab.binding.rflink ] - BundleEvent STARTED - org.openhab.binding.rflink
2019-12-18 10:08:51.871 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-12-18 10:08:52.210 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2019-12-18 10:09:04.558 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-12-18 10:09:06.494 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rflink.things'
2019-12-18 10:09:06.879 [DEBUG] [rflink.internal.RfLinkHandlerFactory] - RfLinkHandlerFactory createHandler(rflink:bridge:usb0)
2019-12-18 10:09:06.903 [DEBUG] [org.openhab.binding.rflink ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=294, service.bundleid=198, service.scope=singleton} - org.openhab.binding.rflink
2019-12-18 10:09:07.776 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.10:8080
2019-12-18 10:09:07.779 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.10:8443
2019-12-18 10:09:08.292 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
This is the content of my .things file
Bridge rflink:bridge:usb0 [ serialPort="/dev/ttyACM0", baudRate=57600 ] {
energy myEnergy [ deviceId="OregonCM119-0004" ]
I am able to “cat” “/dev/ttyACM0” so my rflink is working.
But I am not able to see any device on discovery.
I have already issued the following command on the openhab console:
feature:install openhab-transport-serial
Do I need to do something else?
Thanks in advance!
