Hey David, Im using your enhanced version of RFLinkGateway … but in the original as well as in your version I have trouble with temperature readings… example:
RFLINK/Digitech/00ba/R/BAT OK
RFLINK/Digitech/00ba/R/TEMP 38.3
RFLINK/Digitech/00ba/R/message 20;04;Digitech;ID=00ba;TEMP=017f;BAT=OK;
RFLINK/Prologue/9742/R/TEMP 3277.1
RFLINK/Prologue/9742/R/message 20;05;Prologue;ID=9742;TEMP=8003;
Why is the value that is sent to the controller changed (corrupted?)?
In the first example I would have wanted “017f” to be the value to get to the controller… and “8003” in the second example… Am I missing something?
Edit:
Well I think I understand now… the hex value is translated to decimal… that seems to work as long as we have positive degrees (Celcius)… but when the temperature drops below 0 C it should have calculated 3276.8 (8000h) - 3277.1 (8003h) = -0.3 (my second example)…
[14:26:09] openhabian@openHABianPi:~$ ls
README.txt RFLinkGateway
[14:26:10] openhabian@openHABianPi:~$ cd RFLinkGateway/
[14:26:16] openhabian@openHABianPi:~/RFLinkGateway$ ls
config.json MQTTClient.py readme.md RFLinkGateway.py SerialProcess.py
[14:26:17] openhabian@openHABianPi:~/RFLinkGateway$ sudo chmod +x *.*
[sudo] password for openhabian:
[14:26:32] openhabian@openHABianPi:~/RFLinkGateway$ ./MQTTClient.py &
[1] 30376
[14:27:38] openhabian@openHABianPi:~/RFLinkGateway$ ./MQTTClient.py: line 1: import: command not found
./MQTTClient.py: line 2: import: command not found
./MQTTClient.py: line 3: import: command not found
./MQTTClient.py: line 5: import: command not found
./MQTTClient.py: line 6: import: command not found
./MQTTClient.py: line 9: syntax error near unexpected token `('
./MQTTClient.py: line 9: `class MQTTClient(multiprocessing.Process):'
^C
[1]+ Exit 2 ./MQTTClient.py
[14:27:42] openhabian@openHABianPi:~/RFLinkGateway$ ./RFLinkGateway.py &
[1] 30387
[14:27:54] openhabian@openHABianPi:~/RFLinkGateway$ ./RFLinkGateway.py: line 1: import: command not found
./RFLinkGateway.py: line 2: import: command not found
./RFLinkGateway.py: line 3: import: command not found
./RFLinkGateway.py: line 4: import: command not found
./RFLinkGateway.py: line 5: import: command not found
./RFLinkGateway.py: line 7: import: command not found
./RFLinkGateway.py: line 8: import: command not found
./RFLinkGateway.py: line 9: import: command not found
./RFLinkGateway.py: line 12: import: command not found
./RFLinkGateway.py: line 13: import: command not found
./RFLinkGateway.py: line 15: syntax error near unexpected token `('
./RFLinkGateway.py: line 15: `log_level = os.getenv('RFLINK_LOG_LEVEL', 'INFO')'
^C
[1]+ Exit 2 ./RFLinkGateway.py
[14:28:03] openhabian@openHABianPi:~/RFLinkGateway$ ./SerialProcess.py &
[1] 30405
[14:28:10] openhabian@openHABianPi:~/RFLinkGateway$ ./SerialProcess.py: line 1: import: command not found
./SerialProcess.py: line 2: import: command not found
./SerialProcess.py: line 3: import: command not found
./SerialProcess.py: line 5: import: command not found
./SerialProcess.py: line 7: syntax error near unexpected token `('
./SerialProcess.py: line 7: `class SerialProcess(multiprocessing.Process):'
make sure to adjust the config file accordingly to your needs. The error you are seeing means you don’t have the rights to write the logfile in the /var/log directory
2018-01-09 07:03:20,508 - RFLinkGW.SerialProcessing - __init__ - INFO - Starting...
2018-01-09 07:03:20,511 - RFLinkGW.SerialProcessing - connect - INFO - Connecting to serial
2018-01-09 07:03:20,519 - RFLinkGW.SerialProcessing - __init__ - INFO - Ignoring devices: [u'Friedland', u'Oregon Temp/FD10', u'BL999', u'RTS']
2018-01-09 07:03:20,526 - RFLinkGW.MQTTClient - __init__ - INFO - Starting...
2018-01-09 07:03:20,534 - RFLinkGW.MQTTClient - __init__ - INFO - Connection with credentials (user: user).
2018-01-09 07:03:20,574 - RFLinkGW.MQTTClient - _on_connect - INFO - Connected to broker. Return code: Connection Accepted.
2018-01-09 07:03:21,445 - RFLinkGW.SerialProcessing - prepare_output - INFO - Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R47
2018-01-09 07:51:42,394 - RFLinkGW.SerialProcessing - prepare_output - INFO - Cresta
in the mosquitto.log i see this:
1515481682: New connection from 192.168.1.208 on port 1883.
1515481682: New client connected from 192.168.1.208 as b1d8c5bf-21ea-4c40-aa7b-6273051a891a (c1, k60, u'user').
1515481682: Client b1d8c5bf-21ea-4c40-aa7b-6273051a891a disconnected.
1515481682: New client connected from 192.168.1.208 as 6ad2499a-aab4-44f3-836f-d7d391a6c55f (c1, k60, u'user').
1515481682: Client 6ad2499a-aab4-44f3-836f-d7d391a6c55f disconnected.
1515481682: New client connected from 192.168.1.208 as e91f9d12-0410-4df6-935b-0551e1ee4e64 (c1, k60, u'user').
1515481682: Client e91f9d12-0410-4df6-935b-0551e1ee4e64 disconnected.
1515481684: Socket error on client RFLinkGateway, disconnecting.
1515482591: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515484392: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515486193: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515487994: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515489795: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515491596: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515493397: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515495198: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515496999: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515498801: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515500602: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515502403: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515504204: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515506005: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515507806: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515509607: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
1515510726: Client DVES_862B6C has exceeded timeout, disconnecting.
1515510726: Socket error on client DVES_862B6C, disconnecting.
1515510746: New connection from 192.168.1.71 on port 1883.
1515510746: New client connected from 192.168.1.71 as DVES_862B6C (c1, k15, u'openhabian').
1515511408: Saving in-memory database to /var/lib/mosquitto/mosquitto.db.
i think somewhere is a error, or?
where can i find my devices that rflink has found?
in other tool i find with rflink every few seconds devices infos (e.g. FHEM, Pimatic, Home Assistant)
regard and thx for help
EDIT
here is something:
mosquitto_sub -t "rflink/#"
aa
20;17;Cresta;ID=3D01;TEMP=0456;HUM=aa;BAT=OK;
OK
111.0
86
20;18;Cresta;ID=AB04;TEMP=0016;HUM=86;BAT=OK;
OK
2.2
2.1
OK
1.7
4.0
-0.2
20;19;Cresta;ID=8201;WINDIR=0015;WINSP=0028;WINGS=002c;WINTMP=0011;WINCHL=8002;BAT=OK;
4.4
93
20;1A;Cresta;ID=6703;TEMP=0015;HUM=93;BAT=OK;
OK
2.1
aa
20;1B;Cresta;ID=3D01;TEMP=0456;HUM=aa;BAT=OK;
OK
111.0
0.0
OK
1.8
4.0
-0.2
20;1C;Cresta;ID=8201;WINDIR=0000;WINSP=0028;WINGS=002c;WINTMP=0012;WINCHL=8002;BAT=OK;
4.4
86
20;1D;Cresta;ID=AB04;TEMP=0017;HUM=86;BAT=OK;
OK
2.3
93
20;1E;Cresta;ID=6703;TEMP=0015;HUM=93;BAT=OK;
