RFLink binding
Open a new thread to report the bug
You can also do it on github
113 are the decimal representation of the hexadecimal value 71. So it is probably a missing conversion?
Peter
We dipped into minus temps last night and this fix does not seem to have worked for me. Any ideas?
I know, I had the same.
To be honest, I don’t know. It should work.
I have bumped the gitHub issue but it might be worth opening another one.
Just noticed this comment by Fab33 back in Jan. It has a different value on 3rd line. 0x10000 is replaced with 0x7FFF. I have edited rflink.js accordingly and await the cold again!
…may have to stick my temp sensor in the freezer!
Cool,
Post here if it works
Vincent..
case “TEMP”: result.temp = parseInt(value[1], 16);
if ((result.temp & 0x8000) > 0) { // temperature is an signed int16
result.temp = result.temp & 0x7FFF;
result.temp = 0-result.temp;}
result.temp = result.temp / 10; break;
This works for me.
Yes, my problem was odder than that. I discovered that my sensor was publishing negative value with a different ID. So now I have 2 nodes in node-red for this device…
Vincent, I think you should get in touch with the RFLink guys :wink:
Explanation:
The decoding of the RF data is usually done by reverse engineering (or “guessing”). So the received data is analyzed and looked for the binary representation of the expected values (“node-id”, “battery value”, “measurement value” etc.).
If you notice the id is changing for negative values, then very likely the id bits are wrongly guessed (the sign bit to indicate negative values is wrongly considered to belong to the device id).
Therefore you see the id changing…
Though you already found a way to circumvent this flaw, it’s better to get this fixed by the RFLink firmware itself :wink:
The RFLink mainainers have been quite responsive in the past. If you point them to your findings here and provide useful data, I’d expect them to fix it quick :wink:
There have been no update on the RFLink firmware for over a year now…
I am waiting for the next release and then we’ll see
Well, it’s still alive :wink:
Seems, they are quite busy:
Anyway, I’d suggest posting your findings there or get in direct contact to “Stuntteam” :wink:
Coolio, will do.
I have RFlink setup and “online” in paper UI. I have my RFlink wired to a NRF24L01 so that I can communicate with Milights.
So far I’ve managed to receive info when I tap a remote.
16:29:02.692 [INFO ] [ig.discovery.internal.PersistentInbox] - Added new thing 'rflink:color:usb0:MiLightv1_14BA_00' to inbox.
16:29:02.694 [INFO ] [smarthome.event.InboxAddedEvent      ] - Discovery Result with UID 'rflink:color:usb0:MiLightv1_14BA_00' has been added.
And they show up in my inbox. So I know hardware is functioning properly.
But if I try to add them as things I get errors.
16:29:49.833 [ERROR] [thome.core.thing.binding.ThingFactory] - Thing factory (class org.openhab.binding.rflink.internal.RfLinkHandlerFactory) returned null on create thing when it reports to support the thing type (rflink:color).
16:29:49.844 [WARN ] [ig.discovery.internal.PersistentInbox] - Cannot create thing. No binding found that supports creating a thing of type rflink:color.
Just not sure where to go from here, I know from the documentation that it says send/receive to milight is possible, but there is not much documentation as to how to accomplish this.
Thanks much.
B
For milights, I gave up with RFLink and I went this way:
Super easy to set-up and works a charm
yeah, thats they way i’m going too, I have an ESP8266 coming this week. gonna set it up. thought maybe there might be some advantages, specifically, since I have a wired ethernet connection to the Pi->RFlink this would eliminate the need for a bridge, as the RFlink can communicate directly with the lights. I was hoping this would be a more direct way, as apposed to having the bridge as the middle man. Looks like it would be a lot of work to figure out via RFlink/openhab. I only wish there was a wired version of the bridge.
Thanks!
Looking forward to working with the RFlink binding anyway for my 433 devices.
Hello everybody,
i am looking for a current compiled version of RFLink binding to download.
Could someone provide that?
Thanks in advance
Is there a rflink binding version working on openhab 2.4 ?
Looking for the best way to use rflink. So, same question: Is there a binding working on Openhab 2.4 ?
Hello there,
I made some changes on the OpenHab 2 RfLink plugin, and added some functionalities on the Somfy RTS Rollershutter management.
Full description & setup is available on the Github :
But in a few words :
  • RTS Thing mapped on a virtual RfLink remote (internal RfLink rollingcode system) can now track the rollershutter position by measuring time between commands nd then guessing the shutter position (you only need to specify the time taken by the rollershutter to move from closed to opened)
  • While moving, the current position of the shutter is displayed (1 update/second)
  • You can order the shutter to move to a specific position (like : 80%). the RfLink plugin will then send an order to move the shutter in the right way, and then send a STOP event once the target position is reached.
  • You can “link” existing physical remotes ids, so that the RfLink plugin is able to track the shutter moves from external orders (i.e. you can mix existing remotes orders with RfLink orders)
it is for Openhab 2.3 for now, I will try to compile it for OpenHab 2.4
(BTW : are there any changes on this side ?)
About he 2.4 binding compatibility, I can confirm the RfLink 2.3 “direct” binding (i.e. no MQTT or external scripting) works like a charm on a OpenHab 2.4
(setup : Raspberry Pi 3B+ runnning Raspbian Shelter + Openhab 2.4 installed through Docker)
Installation instructions are available here :
PS : last build also include Discovery support for embedded RTS remotes :
