The RFXCOM binding is working perfectly and I can control QNECT PROFILE RF power plugs with OH2.
With the RFXMngr under Windows, I discovered the HEX RF code of the remote of my garage door by using the undecoded option. However I’m not able to transmit it. Probably I’m doing something wrong but I don’t find any OH2 examples and the documentation is too brief for me.
Manual for mappings says: value1=“description1”. When you press the button with description1, value1 is assigned to the parameter. My sitemap displays the two buttons: OPEN and CLOSE. But if I press on OPEN nothing is transmitted.
I saw I didn’t put the description between quotes. By doing this, the resulting sitemap looks the same and this doesn’t solve the problem either.
