My RFXtrx433E is powered via the USB cable via RPi3 and I’m using a >2A power adaptor (Ipad). I suppose this is sufficient.
After I’m sending the same two signals (ON & OFF) a few times and the power plug functions well there is a timeout and the bridge restarts (see loggings with DEBUG).
I’m able to send signals repeatedly via RFXMgr under Windows. No problems there, so therefore I assume it is an Openhab or Linux problem.
2018-03-31 14:53:21.742 [vent.ItemStateChangedEvent] - Plug_Spare changed from OFF to ON
2018-03-31 14:53:24.039 [ome.event.ItemCommandEvent] - Item 'Plug_Spare' received command OFF
2018-03-31 14:53:24.052 [vent.ItemStateChangedEvent] - Plug_Spare changed from ON to OFF
2018-03-31 14:53:26.429 [ome.event.ItemCommandEvent] - Item 'Plug_Spare' received command ON
2018-03-31 14:53:26.442 [vent.ItemStateChangedEvent] - Plug_Spare changed from OFF to ON
2018-03-31 14:53:28.307 [ome.event.ItemCommandEvent] - Item 'Plug_Spare' received command OFF
2018-03-31 14:53:28.316 [vent.ItemStateChangedEvent] - Plug_Spare changed from ON to OFF
2018-03-31 14:53:29.763 [ome.event.ItemCommandEvent] - Item 'Plug_Spare' received command ON
2018-03-31 14:53:29.775 [vent.ItemStateChangedEvent] - Plug_Spare changed from OFF to ON
2018-03-31 14:53:31.238 [ome.event.ItemCommandEvent] - Item 'Plug_Spare' received command OFF
2018-03-31 14:53:31.246 [vent.ItemStateChangedEvent] - Plug_Spare changed from ON to OFF
2018-03-31 14:53:32.889 [ome.event.ItemCommandEvent] - Item 'Plug_Spare' received command ON
2018-03-31 14:53:32.900 [vent.ItemStateChangedEvent] - Plug_Spare changed from OFF to ON
2018-03-31 14:53:33.712 [hingStatusInfoChangedEvent] - 'rfxcom:bridge:usb1' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2018-03-31 14:53:33.740 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote1_1' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:53:33.754 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote2_3' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:53:33.764 [hingStatusInfoChangedEvent] - 'rfxcom:undecoded:usb1:remoteAliA' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:53:33.775 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remoteAliC' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:53:33.788 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote3_1' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:53:33.794 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote2_2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:53:33.802 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remoteAliD' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:53:33.806 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote3_2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:53:33.810 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remoteAliB' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:53:36.914 [ome.event.ItemCommandEvent] - Item 'Plug_Spare' received command OFF
2018-03-31 14:53:36.921 [vent.ItemStateChangedEvent] - Plug_Spare changed from ON to OFF
2018-03-31 14:53:38.891 [ome.event.ItemCommandEvent] - Item 'Plug_Spare' received command ON
2018-03-31 14:53:38.907 [vent.ItemStateChangedEvent] - Plug_Spare changed from OFF to ON
2018-03-31 14:53:40.606 [ome.event.ItemCommandEvent] - Item 'Plug_Spare' received command OFF
2018-03-31 14:53:40.616 [vent.ItemStateChangedEvent] - Plug_Spare changed from ON to OFF
2018-03-31 14:53:41.975 [ome.event.ItemCommandEvent] - Item 'Plug_Spare' received command ON
2018-03-31 14:53:41.983 [vent.ItemStateChangedEvent] - Plug_Spare changed from OFF to ON
2018-03-31 14:53:43.232 [ome.event.ItemCommandEvent] - Item 'Plug_Spare' received command OFF
2018-03-31 14:53:43.242 [vent.ItemStateChangedEvent] - Plug_Spare changed from ON to OFF
2018-03-31 14:54:20.267 [hingStatusInfoChangedEvent] - 'rfxcom:bridge:usb1' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2018-03-31 14:54:20.291 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote1_1' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:54:20.301 [hingStatusInfoChangedEvent] - 'rfxcom:undecoded:usb1:remoteAliA' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:54:20.309 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote2_3' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:54:20.316 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remoteAliC' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:54:20.325 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote2_2' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:54:20.331 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote3_1' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:54:20.337 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remoteAliD' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:54:20.344 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remoteAliB' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:54:20.347 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote3_2' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:54:27.278 [hingStatusInfoChangedEvent] - 'rfxcom:bridge:usb1' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2018-03-31 14:54:27.295 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote1_1' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:54:27.303 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote3_2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:54:27.333 [hingStatusInfoChangedEvent] - 'rfxcom:undecoded:usb1:remoteAliA' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:54:27.338 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remoteAliB' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:54:27.344 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remoteAliD' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:54:27.348 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remoteAliC' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:54:27.352 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote2_2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:54:27.362 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote3_1' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:54:27.367 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote2_3' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-03-31 14:55:23.665 [hingStatusInfoChangedEvent] - 'rfxcom:bridge:usb1' changed from OFFLINE (COMMUNICATION_ERROR) to ONLINE
2018-03-31 14:55:23.676 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote2_3' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:55:23.695 [hingStatusInfoChangedEvent] - 'rfxcom:undecoded:usb1:remoteAliA' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:55:23.699 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote3_2' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:55:23.702 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote2_2' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:55:23.709 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote1_1' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:55:23.713 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remoteAliB' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:55:23.717 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remote3_1' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:55:23.721 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remoteAliD' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:55:23.724 [hingStatusInfoChangedEvent] - 'rfxcom:lighting5:usb1:remoteAliC' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-03-31 14:50:16.556 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = ONLINE
2018-03-31 14:51:16.559 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = ONLINE
2018-03-31 14:52:16.562 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = ONLINE
2018-03-31 14:53:16.565 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = ONLINE
2018-03-31 14:53:21.721 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:lighting5:usb1:remote3_2:command, command: ON
2018-03-31 14:53:21.736 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitting message 'Raw data = unknown, Packet type = LIGHTING5, Seq number = 0, Sub type = KANGTAI, Device Id = 3884.2, Command = ON, Dim level = 0, Signal level = 0'
2018-03-31 14:53:23.365 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:53:23.369 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitter response received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:53:24.041 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:lighting5:usb1:remote3_2:command, command: OFF
2018-03-31 14:53:24.045 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitting message 'Raw data = unknown, Packet type = LIGHTING5, Seq number = 0, Sub type = KANGTAI, Device Id = 3884.2, Command = OFF, Dim level = 0, Signal level = 0'
2018-03-31 14:53:25.683 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:53:25.689 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitter response received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:53:26.433 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:lighting5:usb1:remote3_2:command, command: ON
2018-03-31 14:53:26.438 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitting message 'Raw data = unknown, Packet type = LIGHTING5, Seq number = 0, Sub type = KANGTAI, Device Id = 3884.2, Command = ON, Dim level = 0, Signal level = 0'
2018-03-31 14:53:28.081 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:53:28.083 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitter response received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:53:28.312 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:lighting5:usb1:remote3_2:command, command: OFF
2018-03-31 14:53:28.317 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitting message 'Raw data = unknown, Packet type = LIGHTING5, Seq number = 0, Sub type = KANGTAI, Device Id = 3884.2, Command = OFF, Dim level = 0, Signal level = 0'
2018-03-31 14:53:29.778 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:lighting5:usb1:remote3_2:command, command: ON
2018-03-31 14:53:29.951 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:53:29.953 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitter response received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:53:29.956 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitting message 'Raw data = unknown, Packet type = LIGHTING5, Seq number = 0, Sub type = KANGTAI, Device Id = 3884.2, Command = ON, Dim level = 0, Signal level = 0'
2018-03-31 14:53:31.242 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:lighting5:usb1:remote3_2:command, command: OFF
2018-03-31 14:53:31.598 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:53:31.602 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitter response received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:53:31.605 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitting message 'Raw data = unknown, Packet type = LIGHTING5, Seq number = 0, Sub type = KANGTAI, Device Id = 3884.2, Command = OFF, Dim level = 0, Signal level = 0'
2018-03-31 14:53:32.895 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:lighting5:usb1:remote3_2:command, command: ON
2018-03-31 14:53:33.631 [DEBUG] [nternal.connector.RFXComStreamReader] - Received exception, will report it to listeners
org.openhab.binding.rfxcom.internal.exceptions.RFXComTimeoutException: Timeout during packet read
at org.openhab.binding.rfxcom.internal.connector.RFXComStreamReader.processMessage(RFXComStreamReader.java:87) [226:org.openhab.binding.rfxcom:2.2.0]
at org.openhab.binding.rfxcom.internal.connector.RFXComStreamReader.run(RFXComStreamReader.java:61) [226:org.openhab.binding.rfxcom:2.2.0]
2018-03-31 14:53:33.689 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred: Timeout during packet read
2018-03-31 14:53:33.708 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged OFFLINE (COMMUNICATION_ERROR) for thing rfxcom:lighting5:usb1:remote1_1
2018-03-31 14:53:33.713 [DEBUG] [nternal.connector.RFXComStreamReader] - Data listener stopped
2018-03-31 14:53:33.713 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge OFFLINE for thing rfxcom:lighting5:usb1:remote1_1
2018-03-31 14:53:33.719 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged OFFLINE (COMMUNICATION_ERROR) for thing rfxcom:lighting5:usb1:remote2_2
2018-03-31 14:53:33.722 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged OFFLINE (COMMUNICATION_ERROR) for thing rfxcom:lighting5:usb1:remote2_3
2018-03-31 14:53:33.726 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged OFFLINE (COMMUNICATION_ERROR) for thing rfxcom:undecoded:usb1:remoteAliA
2018-03-31 14:53:33.727 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge OFFLINE for thing rfxcom:lighting5:usb1:remote2_3
2018-03-31 14:53:33.729 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge OFFLINE for thing rfxcom:undecoded:usb1:remoteAliA
2018-03-31 14:53:33.742 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged OFFLINE (COMMUNICATION_ERROR) for thing rfxcom:lighting5:usb1:remoteAliB
2018-03-31 14:53:33.742 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged OFFLINE (COMMUNICATION_ERROR) for thing rfxcom:lighting5:usb1:remoteAliC
2018-03-31 14:53:33.724 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge OFFLINE for thing rfxcom:lighting5:usb1:remote2_2
2018-03-31 14:53:33.726 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged OFFLINE (COMMUNICATION_ERROR) for thing rfxcom:lighting5:usb1:remote3_1
2018-03-31 14:53:33.749 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge OFFLINE for thing rfxcom:lighting5:usb1:remoteAliC
2018-03-31 14:53:33.749 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge OFFLINE for thing rfxcom:lighting5:usb1:remote3_1
2018-03-31 14:53:33.761 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged OFFLINE (COMMUNICATION_ERROR) for thing rfxcom:lighting5:usb1:remoteAliD
2018-03-31 14:53:33.752 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged OFFLINE (COMMUNICATION_ERROR) for thing rfxcom:lighting5:usb1:remote3_2
2018-03-31 14:53:33.768 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge OFFLINE for thing rfxcom:lighting5:usb1:remote3_2
2018-03-31 14:53:33.765 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge OFFLINE for thing rfxcom:lighting5:usb1:remoteAliD
2018-03-31 14:53:33.762 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge OFFLINE for thing rfxcom:lighting5:usb1:remoteAliB
2018-03-31 14:53:36.918 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:lighting5:usb1:remote3_2:command, command: OFF
2018-03-31 14:53:38.896 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:lighting5:usb1:remote3_2:command, command: ON
2018-03-31 14:53:40.607 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:lighting5:usb1:remote3_2:command, command: OFF
2018-03-31 14:53:41.979 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:lighting5:usb1:remote3_2:command, command: ON
2018-03-31 14:53:43.241 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:lighting5:usb1:remote3_2:command, command: OFF
2018-03-31 14:54:16.570 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = OFFLINE
2018-03-31 14:54:16.572 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Connecting to RFXCOM transceiver
2018-03-31 14:54:16.575 [DEBUG] [rnal.connector.RFXComSerialConnector] - Disconnecting
2018-03-31 14:54:19.578 [DEBUG] [rnal.connector.RFXComSerialConnector] - Serial port event listener stopped
2018-03-31 14:54:19.580 [DEBUG] [rnal.connector.RFXComSerialConnector] - Interrupt serial listener
2018-03-31 14:54:19.583 [DEBUG] [rnal.connector.RFXComSerialConnector] - Close serial out stream
2018-03-31 14:54:19.587 [DEBUG] [rnal.connector.RFXComSerialConnector] - Close serial in stream
2018-03-31 14:54:19.591 [DEBUG] [rnal.connector.RFXComSerialConnector] - Close serial port
2018-03-31 14:54:19.597 [DEBUG] [rnal.connector.RFXComSerialConnector] - Closed
2018-03-31 14:54:19.608 [DEBUG] [rnal.connector.RFXComSerialConnector] - Serial port event listener started
2018-03-31 14:54:19.612 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Reset controller
2018-03-31 14:54:19.621 [DEBUG] [nternal.connector.RFXComStreamReader] - Data listener started
2018-03-31 14:54:19.936 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Get status of controller
2018-03-31 14:54:19.954 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 140100010253180800060001031C04524658434F4D, Packet type = INTERFACE_MESSAGE, Seq number = 1, Sub type = RESPONSE, Command = GET_STATUS, Transceiver type = _433_92MHZ_TRANSCEIVER, Hardware version = 0.1, Firmware type = unknown, Firmware version = 24, Output power = 0dBm, Undecoded packets = false, RFU6 packets = false, Byron SX packets packets (433.92) = false, RSL packets packets (433.92) = false, Lighting4 packets (433.92) = true, FineOffset / Viking (433.92) packets = false, Rubicson (433.92) packets = false, AE (433.92) packets = false, BlindsT1/T2/T3 (433.92) packets = false, BlindsT0 (433.92) packets = false, ProGuard (868.35 FSK) packets = false, FS20/Legrand CAD (868.35/433.92) packets = false, La Crosse (433.92/868.30) packets = false, Hideki/UPM (433.92) packets = false, AD LightwaveRF (433.92) packets = false, Mertik (433.92) packets = false, Visonic (315/868.95) packets = false, ATI (433.92) packets = false, Oregon Scientific (433.92) packets = false, Meiantech (433.92) packets = false, HomeEasy EU (433.92) packets = false, AC (433.92) packets = true, ARC (433.92) packets = true, X10 (310/433.92) packets = false, HomeConfort (433.92) packets = false, KEELOQ (433.92/868.95) packets = false
2018-03-31 14:54:19.959 [INFO ] [g.rfxcom.handler.RFXComBridgeHandler] - RFXCOM transceiver/receiver type: _433_92MHZ_TRANSCEIVER, hw version: 0.1, fw version: 24
2018-03-31 14:54:19.961 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Ignoring transceiver configuration
2018-03-31 14:54:19.964 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Start receiver
2018-03-31 14:54:20.258 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 1401070307436F7079726967687420524658434F4D, Packet type = INTERFACE_MESSAGE, Seq number = 3, Sub type = START_RECEIVER, Command = START_RECEIVER, Text = Copyright RFXCOM
2018-03-31 14:54:20.263 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged ONLINE for thing rfxcom:lighting5:usb1:remote1_1
2018-03-31 14:54:20.264 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged ONLINE for thing rfxcom:lighting5:usb1:remote2_3
2018-03-31 14:54:20.268 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge ONLINE for thing rfxcom:lighting5:usb1:remote1_1
2018-03-31 14:54:20.268 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge ONLINE for thing rfxcom:lighting5:usb1:remote2_3
2018-03-31 14:54:20.263 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged ONLINE for thing rfxcom:lighting5:usb1:remote2_2
2018-03-31 14:54:20.271 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge ONLINE for thing rfxcom:lighting5:usb1:remote2_2
2018-03-31 14:54:20.273 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged ONLINE for thing rfxcom:lighting5:usb1:remote3_1
2018-03-31 14:54:20.273 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged ONLINE for thing rfxcom:lighting5:usb1:remote3_2
2018-03-31 14:54:20.278 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge ONLINE for thing rfxcom:lighting5:usb1:remote3_1
2018-03-31 14:54:20.276 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge ONLINE for thing rfxcom:lighting5:usb1:remote3_2
2018-03-31 14:54:20.283 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged ONLINE for thing rfxcom:lighting5:usb1:remoteAliD
2018-03-31 14:54:20.282 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged ONLINE for thing rfxcom:undecoded:usb1:remoteAliA
2018-03-31 14:54:20.273 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Start TX of any queued messages
2018-03-31 14:54:20.283 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged ONLINE for thing rfxcom:lighting5:usb1:remoteAliB
2018-03-31 14:54:20.286 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge ONLINE for thing rfxcom:undecoded:usb1:remoteAliA
2018-03-31 14:54:20.286 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitting message 'Raw data = unknown, Packet type = LIGHTING5, Seq number = 0, Sub type = KANGTAI, Device Id = 3884.2, Command = OFF, Dim level = 0, Signal level = 0'
2018-03-31 14:54:20.283 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged ONLINE for thing rfxcom:lighting5:usb1:remoteAliC
2018-03-31 14:54:20.287 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge ONLINE for thing rfxcom:lighting5:usb1:remoteAliB
2018-03-31 14:54:20.288 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge ONLINE for thing rfxcom:lighting5:usb1:remoteAliC
2018-03-31 14:54:20.291 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge ONLINE for thing rfxcom:lighting5:usb1:remoteAliD
2018-03-31 14:54:21.919 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:54:21.922 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitter response received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:54:21.926 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitting message 'Raw data = unknown, Packet type = LIGHTING5, Seq number = 0, Sub type = KANGTAI, Device Id = 3884.2, Command = ON, Dim level = 0, Signal level = 0'
2018-03-31 14:54:23.565 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:54:23.569 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitter response received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:54:23.571 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitting message 'Raw data = unknown, Packet type = LIGHTING5, Seq number = 0, Sub type = KANGTAI, Device Id = 3884.2, Command = OFF, Dim level = 0, Signal level = 0'
2018-03-31 14:54:25.213 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:54:25.217 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitter response received: Raw data = 0402010000, Packet type = TRANSMITTER_MESSAGE, Seq number = 0, Sub type = RESPONSE, Response = ACK
2018-03-31 14:54:25.220 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Transmitting message 'Raw data = unknown, Packet type = LIGHTING5, Seq number = 0, Sub type = KANGTAI, Device Id = 3884.2, Command = ON, Dim level = 0, Signal level = 0'
2018-03-31 14:54:27.260 [DEBUG] [nternal.connector.RFXComStreamReader] - Received exception, will report it to listeners
2018-03-31 14:54:27.263 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred: Timeout during packet read
2018-03-31 14:54:27.268 [DEBUG] [nternal.connector.RFXComStreamReader] - Data listener stopped
2018-03-31 14:54:27.268 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - bridgeStatusChanged OFFLINE (COMMUNICATION_ERROR) for thing rfxcom:lighting5:usb1:remote1_1
