- Go to Inbox and click “ + ”
- Click RFXCOM Binding (Do not use the one Autodiscovered by OpenHab)
- Click ADD MANUALLY
- Scroll down and select RFXCOM USB Transceiver
- Provide a unique “Name” that you want or accept the default provided
- Provide a unique “Thing ID” that you want or accept the default provided
- Make sure you select the correct “Serial Port” from the drop down
- Click “ü"
- You should now have a thing named RFXCOM USB Transceiver with “Online” next to it
- Scroll down and select RFXCOM Rfy Actuator
- Select the “Bridge” created in the previous step from the drop down
- In the “Device ID” enter 66564.1
- In the “Sub Type” select “RFY” from the drop down
- Click “ü"
- You should now have a thing named RFXCOM Rfy Actuator with “Online” next to it
- Click on the recently created RFXCOM Rfy Actuator
- Click on Shutter
- Add and link an item
- Now you should be able to control you blind
Let me know if you run into issues.
