I am trying to configure a Brel bidirectional motor in the RFXcom binding but realized this is not supported yet in the binding. It works perfectly through RFXmgr with a RFXtrx433XL. While I posted a feature request, I am wondering if anyone found a workaround to get this working?
Are you aware that with rfxtrx you can record the signal sequences to a raw thing and play this sequence with the connected item? Of course you need a remote control or similar to grab the signal from.
This works very well with my not supported warema shutters.
I went down the https://www.rflink.nl/ route, with a receiver/transmitter.
Recently had some issue with python? re the RFLinkGateway service, so replaced that MQTT functionality with Node RED writing to the Serial port … (NR and RFLINK device are on the same RPi as OH)
Thanks I did not know about Rflink. I checked it out but found it does not support the bidirectional BREL motors (they explicitely state it in the documentation).
Yes I am aware of that but for some reason the RFXcom did not show anything when in capture mode. Maybe I did something wrong. Will give that another try.
In the meantime I am trying a solution by using node js RFXcom with a small API in conjunction with JS rules. First tests are looking good so far.
