I am wondering if anybody in this forum managed to connect rfxcom binding with Sonoff RF (RFR3) using Lighting 4?
I have paired Sonoff with RFXcom using RFXmngr test program and it works. RFXcom bridge/binding works since I am using Somfy things based on Rfy Actuator for awnings
But for Sonoff thing which is in online status I have the following error:
2020-07-14 18:13:01.299 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.rfxcom.internal.handler.RFXComHandler@c485e6': For input string: "D216B1"
java.lang.NumberFormatException: For input string: "D216B1"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:1.8.0_252]
at java.lang.Integer.parseInt(Integer.java:580) ~[?:1.8.0_252]
at java.lang.Integer.parseInt(Integer.java:615) ~[?:1.8.0_252]
The string D216B1 is the the code from RFXmangr while pairing with Sonoff.
PS. I have seen posts on connecting Sonoff/Tasmota using MQTT (which is better
