I would like to add a weather station to my Openhab config. I already have a RFXcom433e in my system for lighting and somfy. Now I’m looking for a weather station integration and was thinking of Alecto WS3500. This is on the list of RFXcom compatible devices, however, I’m not sure if the RFXcom binding will work. Does someone has experience with this?
Hi Jasper I’ve just bought a rfxtrx433e to control my somfy rts shutters. I’ve been able to control them using the rfxmanager tool but I can’t get the binding to work. Are you able to post how you have done your items and site map? Thanks I think my brain is not functioning properly in 2016!
For windows you have to configure the rfxcom binding in openhab.cfg as follow: rfxcom:serialPort=COM1 (or whatever com port your rfxcom is assigned to)
Next you create an item in the openhab items file:
Thanks - so when I run RFXmanager it lists the remotes as follows - how do I map the numbers and which numbers dp I use?
Also for the switch I wanted to have 2 buttons UP and Down or even a slider - did you try this?
EDIT: Ok I figured out the syntax by trial and error:
You take out the zeros for the ID and tag on the Unit ID putting a dot between them.
The switch seems to default to a shutter up down stop buttons which are not great looking but work!
I also have the UP-stop-DOWN buttons.
I don’t think a slider would work, since I do not get feedback from the Somfy when it’s on 100%, like it will with e.g. Zwave device. You could try to see if you get any feedback from the Somfy when it stops at the end-point.
I don’t think feedback is possible? It would be great if the rfx binding updated up when you press buttons on the “real” remotes so that Openhab is always in sync. The other way would be to buy some sensors.
The example above is from my Linux machine, so yes…it’s the same.
You can use the RFXcom manager from their website to determine the addresses to be used.
The configuration of the “item’ shall be like: rfxcom=”>1.0.0.1:RFY.RFY:Shutter" }
the syntax is: RfyMessage Id1.Id2.Id3.UnitCode, so I believe your item will look like be : rfxcom=“1.1.1.1:RFY:RFY:shutter” or rfxcom=“0.0.0.1:RFY:RFY:Shutter”
