RFXCOM doesn't support transmitting for channel 'venetianBlind'
Tags: #<Tag:0x00007fc3fdd531a8>
Hi Guys
I have an issue using the RFXcom in combination with a Somfy led controller.
I am able to use the configuration as a roller shutter where i defined the following item
Rollershutter PergolaLED “LED [%d %%]” (gPergola) {channel=“rfxcom:rfy:a1544f1a:shutter”}
and this works perfect.
up and down enables and disables the leds.
But the controller allows dimming the leds so I defined the venitian blinds.
As the documentation states i should use a long press in order to dim the leds as
the increase and decrease translates to long_up and long_down in the rfxbinding i think the venetian blinds should solve this.
this is done with the following item
Dimmer PergolaLED2 “LED settings [%d %%]” (gPergola) {channel=“rfxcom:rfy:a1544f1a:venetianBlind”}
the logs show the following 2 entries when pushing a button from the dimmer
[DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received channel: rfxcom:rfy:a1544f1a:venetianBlind, command: INCREASE
[WARN ] [binding.rfxcom.handler.RFXComHandler] - RFXCOM doesn’t support transmitting for channel ‘venetianBlind’
the same thing happens when you push the on / off / decrease button.
Anybody an idea why the rfxcom throws this warning ?
Filip
Because the Rfy thing doesn’t allow sending on the Venetian blind channel. See pull request #2689 for the fix. Sorry, I’m not anywhere I can conveniently create a jar for you to test right now.
Mike,
No problem.
I am programming the configuration for a pergola and I still have other things to do.
If there is a test I can do, let it know.
Would also love to test this, no movement on changing the venetian blind scroller.
I have added the new binding with snapshot 2.2.0.201709261356 and the ventian blinds work perfectly !
except the commands seem to be inverted in my setup as light dimmer
If I perform an “ON” command t I see in the debug mode that the OFF_Short command is executed
same thing with the other commands.
OFF = UP_Short
DECREASE=UP_Long
INCREASE=DOWN_long
ON=DOWN_short
could someone with blinds test if this works correctly in the right direction
Which UI addon are you using? I can’t get the venetian slider to work with Paper UI.
Seems I have to learn how HABpanel works right now.
Allways getting ‘can’t convert 68 to comand’, don’t know what to do.
I am using the basic UI to get things going. I am still experimenting with the habpanel.
The main reason for the basic ui is feedback on automatisation. In my case I have a pergola with blinds and I control the blinds in combination with the weather forecast.
The blinds follow the sun to get maximum light inside in the winter and block it in the summer.
I am working on a rain sensor to close the blinds automatically or open them if there is a risk for storm
I just installed the latest firmware 1025 on my RFXtrx433E and I noticed that I can now tilt my blinds by sending the Up and Down Transmit < 0.5sec signal via the RFXmngr app.
I wonder if there are now any plans to implement the venetianBlind dimmer function?
Or if there is another way to get my blinds to tilt.
I am using Somfy blinds.
I’ve got a Renson Algarve pergola with somfy motor and 2 integrated LED-lights, using RFXCOM-binding.
In openhab, I can only use the shutter-channel. In Paper-UI, the “down”-button = led off, the “up”-button = led on and the “stop”-button is turning the LED on at approx. 50%. How can I use the dim-function? I tried the VenetianBlind-channel, but no respons.
Openhab log shows:
“Transmitting error” and “Can’t convert to Command”
Found the solution.
