RFXCOM: Error occurred during packet receiving
Hi all,
I have recently upgraded to OH 2.1. After reinstalling RFXcom in OH 2.1, I found the following exception in my log, which is repeated every minutes:
23:08:15.335 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred during packet receiving, data: 0D0100010253FB0014270001031C
org.openhab.binding.rfxcom.internal.exceptions.RFXComException: java.lang.reflect.InvocationTargetException
	at org.openhab.binding.rfxcom.internal.messages.RFXComMessageFactory.createMessage(RFXComMessageFactory.java:135)[199:org.openhab.binding.rfxcom:2.1.0]
	at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler$MessageListener.packetReceived(RFXComBridgeHandler.java:233)[199:org.openhab.binding.rfxcom:2.1.0]
	at org.openhab.binding.rfxcom.internal.connector.RFXComBaseConnector.sendMsgToListeners(RFXComBaseConnector.java:42)[199:org.openhab.binding.rfxcom:2.1.0]
	at org.openhab.binding.rfxcom.internal.connector.RFXComStreamReader.run(RFXComStreamReader.java:73)[199:org.openhab.binding.rfxcom:2.1.0]
Caused by: java.lang.reflect.InvocationTargetException
	at sun.reflect.GeneratedConstructorAccessor260.newInstance(Unknown Source)[:1.8.0_65]
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)[:1.8.0_65]
	at java.lang.reflect.Constructor.newInstance(Constructor.java:422)[:1.8.0_65]
	at org.openhab.binding.rfxcom.internal.messages.RFXComMessageFactory.createMessage(RFXComMessageFactory.java:130)[199:org.openhab.binding.rfxcom:2.1.0]
	... 3 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: 14
	at org.openhab.binding.rfxcom.internal.messages.RFXComInterfaceMessage.encodeMessage(RFXComInterfaceMessage.java:321)[199:org.openhab.binding.rfxcom:2.1.0]
	at org.openhab.binding.rfxcom.internal.messages.RFXComInterfaceMessage.<init>(RFXComInterfaceMessage.java:211)[199:org.openhab.binding.rfxcom:2.1.0]
	... 7 more
I do not have any idea, what it means and I don´t know how to fix it.
However, it seems that my RFXtrx433 bridge thing is struggeling on it as it switches to OFFLINE and ONLINE a couple of times.
Has anyone an idea?
Kind regards
André
Upgrade the firmware on your RFXCOM. OH2.1 has issues supporting the older firmware types.
@AndreH what version of hard / firmware do you have?
@mjagdis do you think we can keep it compatible with olders version or is it fair to require them to upgrade?
@martinvw: it is HW 1.3 and firmware 251. I have updated to firmware 1020
After upgrading to the current firmware, the error disappeared.
Thank you!!
Hi, I have also upgraded to OH 2.1 and the newest firmware on my RFXCOM (1020).
However, my RFXtrx433 bridge thing does not work – i receive an communication error.
Here ist the log:
17:52:01.426 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred: Read timed out
17:52:01.628 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'rfxcom:tcpbridge:85d27ccc' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR)
After reinstall the older version OH 2.0 everything is ok and the RFXtrx433 bridge is online again:
apt-get --reinstall install openhab2=2.0.0-1
Has anyone an idea how to fix this error in HO 2.1?
Kind regards
rainer
Could you supply some debug logging maybe for both the 2.0.0 version and the 2.1.0 version?
@martinvw,
there are no more entries (rfx or RFX) in the log-file, even if the log-level is set to DEBUG
OH 2.1:
17:38:05.053 [INFO ] [nternal.connector.RFXComTcpConnector] - Connecting to RFXCOM at 192.168.1.112:1001 over TCP/IP
17:38:05.158 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred: Read timed out
OH 2.0
17:49:13.302 [INFO ] [nternal.connector.RFXComTcpConnector] - Connecting to RFXCOM at 192.168.1.112:1001 over TCP/IP
17:49:13.634 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'rfxcom:tcpbridge:85d27ccc' changed from OFFLINE to ONLINE
17:49:13.635 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'rfxcom:lighting1:9737f707:L_0' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
@mjagdis do you think it is likely that this is related to on of the refactorings we did?
i have no idea :roll_eyes:
I created a pull request: https://github.com/openhab/openhab2-addons/pull/2433
If you uninstall the existing rfxcom binding you should be able to place my jar in your addons directory, some searching (on the community forum) should help you out.
Download: https://github.com/openhab/openhab2-addons/files/1122991/org.openhab.binding.rfxcom-2.2.0-SNAPSHOT.jar.zip
PS it is zipped jar, so first unpack before throwing it in the addons directory.
@martinvw
After uninstall the existing rfxcom binding i have installed the org.openhab.binding.rfxcom-2.2.0-SNAPSHOT.jar as described but the result is the same (error timed out).
This happens in both versions the old one (OH 2.0) and the new version (OH 2.1).
I get the RFXtrx433 bridge only run with a fresh install of OH 2.0 (including the rfxcom binding 2.0).
@rainer300
I have added some debug logging, just to be sure can you now, or for the new jar check via the karaf console with bundle:list that the correct bundle is loaded?
I also doubt whether setting debug-ing succeeded, I miss a lot debug message which you must reach. Could you do log:get in karaf and post the result?
You could tail directly from karaf by setting:
log:set TRACE org.openhab.binding.rfxcom
log:tail org.openhab.binding.rfxcom
Download: https://github.com/openhab/openhab2-addons/files/1125679/org.openhab.binding.rfxcom-2.2.0-SNAPSHOT.jar.zip
@martinvw
Now it works :grinning:
What i have done:
  • apt-get upgrade (-> OH 2.1)
  • uninstall the rfxcom-Binding (paperui)
  • download an place the new .jar (2.2.0.201707051837 - your link above) in my addons directory
  • restart openhab2
Thanks for your help!!
Hi there,
Hope you don’t mind me joining this thread…
I tried your snapshot version of the binding; when I add a new thing manually through paper UI, openhab2 crashes:
openhab.log:
2017-07-09 20:22:52.231 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.97:8080
2017-07-09 20:23:07.699 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.97:8443
2017-07-09 20:23:07.873 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-07-09 20:23:08.560 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2017-07-09 20:23:08.575 [DEBUG] [org.openhab.binding.rfxcom          ] - BundleEvent STARTING - org.openhab.binding.rfxcom
2017-07-09 20:23:08.577 [DEBUG] [org.openhab.binding.rfxcom          ] - BundleEvent STARTED - org.openhab.binding.rfxcom
2017-07-09 20:23:08.596 [DEBUG] [org.openhab.binding.rfxcom          ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={component.name=org.openhab.binding.rfxcom.discovery, component.id=160, service.id=282, service.bundleid=186, service.scope=bundle} - org.openhab.binding.rfxcom
2017-07-09 20:23:08.631 [DEBUG] [org.openhab.binding.rfxcom          ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.rfxcom.internal.RFXComHandlerFactory, component.id=161, service.id=283, service.bundleid=186, service.scope=bundle} - org.openhab.binding.rfxcom
2017-07-09 20:24:54.842 [DEBUG] [org.openhab.binding.rfxcom          ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=286, service.bundleid=186, service.scope=singleton} - org.openhab.binding.rfxcom
2017-07-09 20:24:54.870 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Initializing RFXCOM bridge handler
2017-07-09 20:24:54.908 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = OFFLINE
2017-07-09 20:24:54.909 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Connecting to RFXCOM transceiver
2017-07-09 20:24:54.933 [DEBUG] [rnal.connector.RFXComSerialConnector] - Disconnecting
2017-07-09 20:24:54.934 [DEBUG] [rnal.connector.RFXComSerialConnector] - Closed
Karaf console:
                          __  _____    ____
  ____  ____  ___  ____  / / / /   |  / __ )
 / __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __  |
/ /_/ / /_/ /  __/ / / / __  / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/  |_/_____/
    /_/                        2.1.0
                               - release build -
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab> smarthome:items list
No item found for this pattern.
openhab> smarthome:things list
No things found.
openhab> Connection to localhost closed by remote host.
Connection to localhost closed.
pi@openhab /usr/share/openhab2 $
Happy to help debug where I’m able…
Cheers
James
What hardware / kernel are you running one? Is it maybe similar to the issues described at the bottom of:
https://github.com/openhab/openhab2-addons/issues/1312
Hi Martin,
I’ll need to check kernel, running wheezy on an rpi3.
That said, the issue you reference mirrors exactly my experiences, when I’m home later I’ll run in debug as suggested and see if I get anything additional.
Thank you - I was beginning to think I was going mad at not being able to solve this!
Cheers
James
Hi Martin,
Is this the kernel version you require:
pi@openhab /var/log/openhab2 $ cat /proc/version
Linux version 4.4.20-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #908 SMP Wed Sep 7 14:44:27 BST 2016
I also get the same error from the karaf console:
08:05:43.518 [DEBUG] [org.openhab.binding.rfxcom          ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=288, service.bundleid=186, service.scope=singleton} - org.openhab.binding.rfxcom
08:05:43.542 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Initializing RFXCOM bridge handler
08:05:43.548 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = OFFLINE
08:05:43.549 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Connecting to RFXCOM transceiver
08:05:43.571 [DEBUG] [rnal.connector.RFXComSerialConnector] - Disconnecting
08:05:43.575 [DEBUG] [rnal.connector.RFXComSerialConnector] - Closed
/usr/bin/java: symbol lookup error: /var/lib/openhab2/tmp/libNRJavaSerial_HF_root_0/libNRJavaSerial_HF.so: undefined symbol: __fdelt_chk
James
Hi Martin,
I’ve upgraded my rpi to jessie which includes the libc upgraded version and the RFXcom appears to be working sweetly!
Many thanks
James
I’ve a similar problem. Tested with Rfxtrx433E batch 1015 and Software Version 1035 / 1026. Could not download / test Version 1020.
The Rfxtrx is connected via USB to a raspberry pi and running socat.
socat tcp-listen:10000,fork,reuseaddr file:/dev/ttyUSB0,raw
After receiving of a signal I get a timeout and the datalistener stopped. Actually only one device sending messages wich are received and encoded correctly when I use RFXmngr.
cat /proc/version
Linux version 4.4.0-142-generic (buildd@lgw01-amd64-033) (gcc version 5.4.0 20160609 (Ubuntu5.4.0-6ubuntu1~16.04.10) ) #168-Ubuntu SMP Wed Jan 16 21:00:45 UTC 2019
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.5 LTS
Release:        16.04
Codename:       xenial
ldd --version
ldd (Ubuntu GLIBC 2.23-0ubuntu10) 2.23
openhab> version
4.2.1
openhab> log:set TRACE org.openhab.binding.rfxcom
openhab> log:tail org.openhab.binding.rfxcom
10:32:47.194 [INFO ] [internal.connector.RFXComTcpConnector] - Connecting to RFXCOM at 192.168.1.11:10000 over TCP/IP
10:32:47.196 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Reset controller
10:32:47.198 [TRACE] [internal.connector.RFXComTcpConnector] - Send data (len=14): 0D00000000000000000000000000
10:32:47.199 [DEBUG] [internal.connector.RFXComStreamReader] - Data listener started
10:32:47.498 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Get status of controller
10:32:47.499 [TRACE] [internal.connector.RFXComTcpConnector] - Send data (len=14): 0D00000102000000000000000000
10:33:47.500 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = OFFLINE
10:33:47.502 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Connecting to RFXCOM transceiver
10:33:47.502 [DEBUG] [internal.connector.RFXComTcpConnector] - Disconnecting
10:33:47.503 [DEBUG] [internal.connector.RFXComTcpConnector] - Interrupt stream listener
10:33:47.565 [DEBUG] [internal.connector.RFXComStreamReader] - Data listener stopped
10:33:47.566 [DEBUG] [internal.connector.RFXComTcpConnector] - Close tcp out stream
10:33:47.567 [DEBUG] [internal.connector.RFXComTcpConnector] - Close tcp in stream
10:33:47.573 [DEBUG] [internal.connector.RFXComTcpConnector] - Close socket
10:33:47.574 [DEBUG] [internal.connector.RFXComTcpConnector] - Closed
10:33:47.575 [INFO ] [internal.connector.RFXComTcpConnector] - Connecting to RFXCOM at 192.168.1.11:10000 over TCP/IP
10:33:47.581 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Reset controller
10:33:47.582 [TRACE] [internal.connector.RFXComTcpConnector] - Send data (len=14): 0D00000000000000000000000000
10:33:47.583 [DEBUG] [internal.connector.RFXComStreamReader] - Data listener started
10:33:47.882 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Get status of controller
10:33:47.883 [TRACE] [internal.connector.RFXComTcpConnector] - Send data (len=14): 0D00000102000000000000000000
10:34:08.974 [DEBUG] [internal.connector.RFXComStreamReader] - Received exception, will report it to listeners
org.openhab.binding.rfxcom.internal.exceptions.RFXComTimeoutException: Timeout during packet read
        at org.openhab.binding.rfxcom.internal.connector.RFXComStreamReader.processMessage(RFXComStreamReader.java:87) ~[213:org.openhab.binding.rfxcom:2.4.0]
        at org.openhab.binding.rfxcom.internal.connector.RFXComStreamReader.run(RFXComStreamReader.java:61) [213:org.openhab.binding.rfxcom:2.4.0]
10:34:08.976 [ERROR] [ng.rfxcom.handler.RFXComBridgeHandler] - Error occurred: Timeout during packet read
10:34:08.979 [DEBUG] [internal.connector.RFXComStreamReader] - Data listener stopped
10:34:47.884 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = OFFLINE
10:34:47.885 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Connecting to RFXCOM transceiver
10:34:47.885 [DEBUG] [internal.connector.RFXComTcpConnector] - Disconnecting
10:34:47.885 [DEBUG] [internal.connector.RFXComTcpConnector] - Interrupt stream listener
10:34:47.887 [DEBUG] [internal.connector.RFXComTcpConnector] - Close tcp out stream
10:34:47.887 [DEBUG] [internal.connector.RFXComTcpConnector] - Close tcp in stream
10:34:47.887 [DEBUG] [internal.connector.RFXComTcpConnector] - Close socket
10:34:47.888 [DEBUG] [internal.connector.RFXComTcpConnector] - Closed
10:34:47.891 [INFO ] [internal.connector.RFXComTcpConnector] - Connecting to RFXCOM at 192.168.1.11:10000 over TCP/IP
10:34:47.893 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Reset controller
10:34:47.893 [TRACE] [internal.connector.RFXComTcpConnector] - Send data (len=14): 0D00000000000000000000000000
10:34:47.902 [DEBUG] [internal.connector.RFXComStreamReader] - Data listener started
10:34:48.195 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Get status of controller
10:34:48.195 [TRACE] [internal.connector.RFXComTcpConnector] - Send data (len=14): 0D00000102000000000000000000
10:35:48.196 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = OFFLINE
10:35:48.200 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Connecting to RFXCOM transceiver
10:35:48.201 [DEBUG] [internal.connector.RFXComTcpConnector] - Disconnecting
10:35:48.202 [DEBUG] [internal.connector.RFXComTcpConnector] - Interrupt stream listener
10:35:48.261 [DEBUG] [internal.connector.RFXComStreamReader] - Data listener stopped
10:35:48.263 [DEBUG] [internal.connector.RFXComTcpConnector] - Close tcp out stream
10:35:48.265 [DEBUG] [internal.connector.RFXComTcpConnector] - Close tcp in stream
10:35:48.269 [DEBUG] [internal.connector.RFXComTcpConnector] - Close socket
10:35:48.271 [DEBUG] [internal.connector.RFXComTcpConnector] - Closed
10:35:48.280 [INFO ] [internal.connector.RFXComTcpConnector] - Connecting to RFXCOM at 192.168.1.11:10000 over TCP/IP
10:35:48.286 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Reset controller
10:35:48.288 [TRACE] [internal.connector.RFXComTcpConnector] - Send data (len=14): 0D00000000000000000000000000
10:35:48.294 [DEBUG] [internal.connector.RFXComStreamReader] - Data listener started
10:35:48.591 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Get status of controller
10:35:48.594 [TRACE] [internal.connector.RFXComTcpConnector] - Send data (len=14): 0D00000102000000000000000000
10:36:11.975 [DEBUG] [internal.connector.RFXComStreamReader] - Received exception, will report it to listeners
10:36:11.986 [ERROR] [ng.rfxcom.handler.RFXComBridgeHandler] - Error occurred: Timeout during packet read
10:36:11.991 [DEBUG] [internal.connector.RFXComStreamReader] - Data listener stopped
10:36:34.115 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Handler disposed.
10:36:34.118 [DEBUG] [internal.connector.RFXComTcpConnector] - Disconnecting
10:36:34.120 [DEBUG] [internal.connector.RFXComTcpConnector] - Interrupt stream listener
10:36:34.121 [DEBUG] [internal.connector.RFXComTcpConnector] - Close tcp out stream
10:36:34.125 [DEBUG] [internal.connector.RFXComTcpConnector] - Close tcp in stream
10:36:34.133 [DEBUG] [internal.connector.RFXComTcpConnector] - Close socket
10:36:34.134 [DEBUG] [internal.connector.RFXComTcpConnector] - Closed
Fixed the issue.
socat tcp-listen:10001,fork,reuseaddr file:/dev/ttyUSB0,b38400,raw
I did also a change from the pro type software to the ext type software and found th 1020 Version. But only adding baud to socat fixed the issue.
Maybe it would be good to mention the minimum software version and the baud in the documentation.
Now I’m wondering why the connection is still offline and the system always reconnect.
16:12:33.671 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = OFFLINE
16:12:33.673 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Connecting to RFXCOM transceiver
16:12:33.674 [DEBUG] [internal.connector.RFXComTcpConnector] - Disconnecting
16:12:33.681 [DEBUG] [internal.connector.RFXComTcpConnector] - Interrupt stream listener
16:12:33.699 [DEBUG] [internal.connector.RFXComStreamReader] - Data listener stopped
16:12:33.701 [DEBUG] [internal.connector.RFXComTcpConnector] - Close tcp out stream
16:12:33.703 [DEBUG] [internal.connector.RFXComTcpConnector] - Close tcp in stream
16:12:33.705 [DEBUG] [internal.connector.RFXComTcpConnector] - Close socket
16:12:33.707 [DEBUG] [internal.connector.RFXComTcpConnector] - Closed
16:12:33.710 [INFO ] [internal.connector.RFXComTcpConnector] - Connecting to RFXCOM at 192.168.1.12:10001 over TCP/IP
16:12:33.724 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Reset controller
16:12:33.726 [TRACE] [internal.connector.RFXComTcpConnector] - Send data (len=14): 0D00000000000000000000000000
16:12:33.732 [DEBUG] [internal.connector.RFXComStreamReader] - Data listener started
16:12:34.028 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Get status of controller
16:12:34.029 [TRACE] [internal.connector.RFXComTcpConnector] - Send data (len=14): 0D00000102000000000000000000
16:13:04.520 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0A5201007A0200E6240259, Packet type = TEMPERATURE_HUMIDITY, Seq number = 0, Sub type = TH1, Device Id = 31234, Temperature = 23.0, Humidity = 36, Humidity status = DRY, Signal level = 5, Battery level = 9
16:13:04.523 [TRACE] [iscovery.RFXComDeviceDiscoveryService] - Received: bridge: rfxcom:tcpbridge:rp_wohnzimmer message: Raw data = 0A5201007A0200E6240259, Packet type = TEMPERATURE_HUMIDITY, Seq number = 0, Sub type = TH1, Device Id = 31234, Temperature = 23.0, Humidity = 36, Humidity status = DRY, Signal level = 5, Battery level = 9
16:13:04.525 [TRACE] [iscovery.RFXComDeviceDiscoveryService] - Adding new RFXCOM rfxcom:temperaturehumidity:rp_wohnzimmer:31234 with id '31234' to smarthome inbox
16:13:04.526 [DEBUG] [.binding.rfxcom.handler.RFXComHandler] - Received message from bridge: rfxcom:tcpbridge:rp_wohnzimmer message: Raw data = 0A5201007A0200E6240259, Packet type = TEMPERATURE_HUMIDITY, Seq number = 0, Sub type = TH1, Device Id = 31234, Temperature = 23.0, Humidity = 36, Humidity status = DRY, Signal level = 5, Battery level = 9
16:13:25.538 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0A520101960100AB120240, Packet type = TEMPERATURE_HUMIDITY, Seq number = 1, Sub type = TH1, Device Id = 38401, Temperature = 17.1, Humidity = 18, Humidity status = DRY, Signal level = 4, Battery level = 0
16:13:25.540 [TRACE] [iscovery.RFXComDeviceDiscoveryService] - Received: bridge: rfxcom:tcpbridge:rp_wohnzimmer message: Raw data = 0A520101960100AB120240, Packet type = TEMPERATURE_HUMIDITY, Seq number = 1, Sub type = TH1, Device Id = 38401, Temperature = 17.1, Humidity = 18, Humidity status = DRY, Signal level = 4, Battery level = 0
16:13:25.541 [TRACE] [iscovery.RFXComDeviceDiscoveryService] - Adding new RFXCOM rfxcom:temperaturehumidity:rp_wohnzimmer:38401 with id '38401' to smarthome inbox
16:13:25.543 [DEBUG] [.binding.rfxcom.handler.RFXComHandler] - Received message from bridge: rfxcom:tcpbridge:rp_wohnzimmer message: Raw data = 0A520101960100AB120240, Packet type = TEMPERATURE_HUMIDITY, Seq number = 1, Sub type = TH1, Device Id = 38401, Temperature = 17.1, Humidity = 18, Humidity status = DRY, Signal level = 4, Battery level = 0
16:13:34.031 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Checking RFXCOM transceiver connection, thing status = OFFLINE
16:13:34.033 [DEBUG] [ng.rfxcom.handler.RFXComBridgeHandler] - Connecting to RFXCOM transceiver
16:13:34.035 [DEBUG] [internal.connector.RFXComTcpConnector] - Disconnecting
16:13:34.036 [DEBUG] [internal.connector.RFXComTcpConnector] - Interrupt stream listener
16:13:34.068 [DEBUG] [internal.connector.RFXComStreamReader] - Data listener stopped
16:13:34.070 [DEBUG] [internal.connector.RFXComTcpConnector] - Close tcp out stream
16:13:34.072 [DEBUG] [internal.connector.RFXComTcpConnector] - Close tcp in stream
16:13:34.074 [DEBUG] [internal.connector.RFXComTcpConnector] - Close socket
16:13:34.075 [DEBUG] [internal.connector.RFXComTcpConnector] - Closed
