I’ve got an RFXCOM device which sends and receives known protocols via OH. It also receives undecoded packets which I process in a rules file.
Is there a way of sending an raw packet using the RFXCOM binding?
In the RFXCOM windows app there is a Raw Transmit tab and using this I can send a txt file containing the raw timings which works well, and I would like to do this in OH.
Documentation appears to say yes. Does it not work for you?
Please search the documentation.
Examples
###undecoded - RFXCOM Undecoded RF Messages
Any messages that RFXCOM can receive but not decode.
From
I already receive and use undecoded messages which I think the documentation refers to. I need to SEND them which as far as I can see it doesn’t refer to. I want to SEND undecoded messages stored in a timings file.
I have read the documentation several times and searched the forum but I can’t seem to find how to SEND a raw timings file
Since the documentation says the RXFCOM device receives these messages, it implies they are sent through the binding.
True, but how?
Mapping a String Item to the RFXCOM Undecoded RF Messages Message Thing doesn’t work and spits
An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.rfxcom.internal.handler.RFXComHandler@6701ca59': Unknown packet type UNDECODED
when a message is sent
If nobody using that binding responds, try opening an Issue on GitHub to get direct developer input on a possible bug.
Issue logged and it’s been tagged as an enhancement
Have you find a solution?
No, it seems there is no development on this binding. There’s an open GitHub issue too with no replies
I’m working on this, see [rfxcom] Sending RAW String doesn't work · Issue #6769 · openhab/openhab-addons · GitHub if you want to help test.
In short, you cannot send an undecoded message, but you can send a raw message. They are different, but as long as it’s just repeating a message from a device, it works.
