Using RFXcom binding on openHAB, added new (chinees lightning4 actuator to the network. Unfortunately it is not fully supported yet by the RFXcom binding I’m using. Can the binding be updated so this acutator will be supported?
Platform = Raspberry Pi 3 Model B Rev 1.2
openHAB 2.4.0-1 (Release Build)
RFXCom binding 2.4.0
Enabled debug logging for RFXcom and this is logged:
2019-09-21 08:27:02.188 [INFO ] [rnal.messages.RFXComLighting4Message] - A not completely supported command with value 6 was received, we can send it but please report it as an issue including what the command means, this helps to extend the binding with better support. 2019-09-21 08:27:02.190 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 091300F614240601A560, Packet type = LIGHTING4, Seq number = 246, Sub type = PT2262, Device Id = 82496, Command = UNKNOWN(6), Pulse = 421 2019-09-21 08:27:02.201 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Received message from bridge: rfxcom:bridge:usb1 message: Raw data = 091300F614240601A560, Packet type = LIGHTING4, Seq number = 246, Sub type = PT2262, Device Id = 82496, Command = UNKNOWN(6), Pulse = 421
