The RFXCOM transceiver can perfectly decode the remote control signal, and it even shows up in openHAB(2.4) Inbox, but after adding it just goes straight offline with configuration error: “RFXCOM device missing deviceId or subType”.
The deviceId has been added automatically and the subType is not changeable. I tried adding the Thing manually, same result.
2019-05-31 04:52:29.366 [DEBUG] [ore.thing.internal.ThingRegistryImpl] - Creating thing for type 'rfxcom:security2'.
2019-05-31 04:52:29.380 [DEBUG] [core.thing.internal.ThingManagerImpl] - Thing 'rfxcom:security2:40782f6e' is tracked by ThingManager.
2019-05-31 04:52:29.381 [DEBUG] [core.thing.internal.ThingManagerImpl] - Calling 'RFXComHandlerFactory.registerHandler()' for thing 'rfxcom:security2:40782f6e'.
2019-05-31 04:52:29.382 [DEBUG] [core.thing.internal.ThingManagerImpl] - Configuration of 'rfxcom:security2:40782f6e' needs [deviceId], has [deviceId].
2019-05-31 04:52:29.382 [DEBUG] [core.thing.internal.ThingManagerImpl] - Config description for 'rfxcom:contact' is not resolvable, assuming 'rfxcom:security2:40782f6e:contact' is initializable
2019-05-31 04:52:29.383 [DEBUG] [core.thing.internal.ThingManagerImpl] - Config description for 'rfxcom:contact' is not resolvable, assuming 'rfxcom:security2:40782f6e:contact1' is initializable
2019-05-31 04:52:29.383 [DEBUG] [core.thing.internal.ThingManagerImpl] - Config description for 'rfxcom:contact' is not resolvable, assuming 'rfxcom:security2:40782f6e:contact2' is initializable
2019-05-31 04:52:29.384 [DEBUG] [core.thing.internal.ThingManagerImpl] - Config description for 'rfxcom:contact' is not resolvable, assuming 'rfxcom:security2:40782f6e:contact3' is initializable
2019-05-31 04:52:29.384 [DEBUG] [core.thing.internal.ThingManagerImpl] - Config description for 'system:signal-strength' is not resolvable, assuming 'rfxcom:security2:40782f6e:signalLevel' is initializable
2019-05-31 04:52:29.385 [DEBUG] [core.thing.internal.ThingManagerImpl] - Config description for 'system:battery-level' is not resolvable, assuming 'rfxcom:security2:40782f6e:batteryLevel' is initializable
2019-05-31 04:52:29.386 [DEBUG] [core.thing.internal.ThingManagerImpl] - Calling initialize handler for thing 'rfxcom:security2:40782f6e' at 'org.openhab.binding.rfxcom.handler.RFXComHandler@1e972b2a'.
2019-05-31 04:52:29.386 [hingStatusInfoChangedEvent] - 'rfxcom:security2:40782f6e' changed from UNINITIALIZED to INITIALIZING
2019-05-31 04:52:29.388 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - Initializing thing rfxcom:security2:40782f6e
2019-05-31 04:52:29.389 [DEBUG] [binding.rfxcom.handler.RFXComHandler] - initializeBridge ONLINE for thing rfxcom:security2:40782f6e
2019-05-31 04:52:29.392 [hingStatusInfoChangedEvent] - 'rfxcom:security2:40782f6e' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): RFXCOM device missing deviceId or subType
2019-05-31 04:52:29.393 [DEBUG] [mon.registry.AbstractManagedProvider] - Added new element rfxcom:security2:40782f6e to ManagedThingProvider.
