I have installed new version of OH2.1.0 on an win10 machine with java 8u101
(I also have tried on WIN7 )
THe RFXtrx works with the RFXCOM manager software including fetching temperature data but not in openhab.
I have a problem in that I cannot get the RFXTRX433 receiver to work
Sometimes it does not show up in paper ui during discover - sometimes it does after delete.
I tried adding manually with COM7 .
both automatic and manual added have status OFFLINE
I tried to remove the FTDI driver package using powershell
first command
pnputil.exe -e
gives response
Published name : oem69.inf
Driver package provider : FTDI
Class : USB-styrenheter
Driver date and version : 08/16/2017 2.12.28.0
Signer name : Microsoft Windows Hardware Compatibility Publisher
Published name : oem70.inf
Class : Portar (COM och LPT)
so I try with commands
pnputil.exe -d oem69.inf
pnputil.exe -d oem70.inf
response is
Deleting the driver package failed : at least on unit is installed with the INF-file
I remove the RFXTRX433 and then I am able to delete oem69,inf but not oem.70inf
When I insert RFXtrx433 into USB it seems as drivers are installed again.
is there something I am missing?
some loginfo:
----------openhab.log
2017-10-06 17:27:50.605 [INFO ] [ernal.connector.RFXComJD2XXConnector] - Connecting to RFXCOM device ‘A1WRPW4D’ using JD2XX.
2017-10-06 17:27:50.607 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Connection to RFXCOM transceiver failed
java.io.IOException: device not opened (3)
at jd2xx.JD2XX.openEx(Native Method)[182:org.openhab.binding.rfxcom:2.1.0]
at jd2xx.JD2XX.openBySerialNumber(JD2XX.java:806)[182:org.openhab.binding.rfxcom:2.1.0]
at org.openhab.binding.rfxcom.internal.connector.RFXComJD2XXConnector.connect(RFXComJD2XXConnector.java:45)[182:org.openhab.binding.rfxcom:2.1.0]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler.connect(RFXComBridgeHandler.java:183)[182:org.openhab.binding.rfxcom:2.1.0]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler.access$7(RFXComBridgeHandler.java:163)[182:org.openhab.binding.rfxcom:2.1.0]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler$1.run(RFXComBridgeHandler.java:156)[182:org.openhab.binding.rfxcom:2.1.0]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)[:1.8.0_101]
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)[:1.8.0_101]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)[:1.8.0_101]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)[:1.8.0_101]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)[:1.8.0_101]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)[:1.8.0_101]
at java.lang.Thread.run(Unknown Source)[:1.8.0_101]
2017-10-06 17:27:50.608 [INFO ] [g.rfxcom.handler.RFXComBridgeHandler] - Automatically Discovered RFXCOM bridges use FTDI chip driver (D2XX). Reason for this error normally is related to operating system native FTDI drivers, which prevent D2XX driver to open device. To solve this problem, uninstall OS FTDI native drivers or add manually universal bridge ‘RFXCOM USB Transceiver’, which use normal serial port driver rather than D2XX.
2017-10-06 17:28:15.507 [INFO ] [ernal.connector.RFXComJD2XXConnector] - Connecting to RFXCOM device ‘A1WRPW4D’ using JD2XX.
2017-10-06 17:28:15.620 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred: io error
2017-10-06 17:28:31.020 [INFO ] [ernal.connector.RFXComJD2XXConnector] - Connecting to RFXCOM device ‘COM7’ using JD2XX.
2017-10-06 17:28:31.143 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Connection to RFXCOM transceiver failed
java.io.IOException: device not found (2)
2017-10-06 17:28:40.935 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘rfxcom:RFXtrx433:A1WRPW4D’ to inbox.
2017-10-06 17:29:01.965 [INFO ] [ernal.connector.RFXComJD2XXConnector] - Connecting to RFXCOM device ‘A1WRPW4D’ using JD2XX.
2017-10-06 17:29:15.044 [INFO ] [ernal.connector.RFXComJD2XXConnector] - Connecting to RFXCOM device ‘A1WRPW4D’ using JD2XX.
2017-10-06 17:30:15.161 [INFO ] [ernal.connector.RFXComJD2XXConnector] - Connecting to RFXCOM device ‘A1WRPW4D’ using JD2XX.
2017-10-06 17:30:15.274 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred: io error
----------event.log
2017-10-06 17:29:01.958 [ThingAddedEvent ] - Thing ‘rfxcom:RFXtrx433:A1WRPW4D’ has been added.
2017-10-06 17:29:01.965 [hingStatusInfoChangedEvent] - ‘rfxcom:RFXtrx433:A1WRPW4D’ changed from INITIALIZING to OFFLINE
2017-10-06 17:29:01.965 [hingStatusInfoChangedEvent] - ‘rfxcom:RFXtrx433:A1WRPW4D’ changed from UNINITIALIZED to INITIALIZING
2017-10-06 17:29:15.044 [ThingUpdatedEvent ] - Thing ‘rfxcom:RFXtrx433:A1WRPW4D’ has been updated.
2017-10-06 17:30:15.473 [hingStatusInfoChangedEvent] - ‘rfxcom:RFXtrx433:A1WRPW4D’ changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR)
2017-10-06 17:30:24.946 [hingStatusInfoChangedEvent] - ‘rfxcom:RFXtrx433:A1WRPW4D’ changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE
2017-10-06 17:30:24.946 [ThingUpdatedEvent ] - Thing ‘rfxcom:RFXtrx433:A1WRPW4D’ has been updated.
2017-10-06 17:30:24.951 [ThingUpdatedEvent ] - Thing ‘rfxcom:RFXtrx433:A1WRPW4D’ has been updated.
2017-10-06 17:31:25.377 [hingStatusInfoChangedEvent] - ‘rfxcom:RFXtrx433:A1WRPW4D’ changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR)
2017-10-06 17:32:31.979 [ExtensionEvent ] - Extension ‘ui-habmin’ has been installed.
