Hi Guys,
Admittedly I new to OpenHAB but i think i have tired eveything and simply cant get the RFXCOM binding to find my RFXtrx433. If anyone can give me a pointer i would be very appreciative, the steps so far:
- It wasn’t automatically picked up by Paper UI, so i tried adding manually via Paper UI. Shows as offline
- Tried adding openhab user to the dialout group - Still shows as offline and gets the error below
- Tried setting the symlinks as per the example (including add it to the openhab2 file - still gets the error below
- Tried setting the symlinks to ttyUSB-9999 and removing the line for the openhab2 file - still gets the error below
Not sure what my next step should be… I am using a snapshot build from 2 days ago on a Pi3
2016-08-29 15:14:50.401 [INFO ] [ernal.connector.RFXComJD2XXConnector] - Connecting to RFXCOM device ‘A1WXPMFX’.
2016-08-29 15:14:50.409 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Connection to RFXCOM transceiver failed
java.io.IOException: device not found (2)
at jd2xx.JD2XX.openEx(Native Method)[190:org.openhab.binding.rfxcom:2.0.0.201608210102]
at jd2xx.JD2XX.openBySerialNumber(JD2XX.java:806)[190:org.openhab.binding.rfxcom:2.0.0.201608210102]
at org.openhab.binding.rfxcom.internal.connector.RFXComJD2XXConnector.connect(RFXComJD2XXConnector.java:56)[190:org.openhab.binding.rfxcom:2.0.0.201608210102]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler.connect(RFXComBridgeHandler.java:161)[190:org.openhab.binding.rfxcom:2.0.0.201608210102]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler.access$8(RFXComBridgeHandler.java:141)[190:org.openhab.binding.rfxcom:2.0.0.201608210102]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler$1.run(RFXComBridgeHandler.java:114)[190:org.openhab.binding.rfxcom:2.0.0.201608210102]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_65]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)[:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)[:1.8.0_65]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_65]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
