Hi openHABies,
another problem from a newbie - trying to get RFXCOM binding to work.
I got a RFXtrx433E, connected to the Windows machine (Win Server 2008R2), RFXMGR working fine - receiving and sending commands no problem.
Auto-Discovery via PaperUI works fine as well, RFXtrx433E is found and added to the Things List.
Unfortunately, it stays offline.
Logfile says:
2017-09-13 22:46:54.798 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'rfxcom:RFXtrx433:A11HET9T' to inbox.
2017-09-13 22:47:08.090 [INFO ] [ernal.connector.RFXComJD2XXConnector] - Connecting to RFXCOM device 'A11HET9T' using JD2XX.
2017-09-13 22:48:08.508 [INFO ] [ernal.connector.RFXComJD2XXConnector] - Connecting to RFXCOM device 'A11HET9T' using JD2XX.
2017-09-13 22:48:09.117 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occurred: io error
I tried to manually add it via Serial Port (COM3) where it stays online, but doesn’t show any new items in Inbox when i press a remote button.
Tried to de-install the FTDI Windows Driver, but same problem, Bridge stays offline.
Still, direct communication from RFXMgr works fine.
Anyone has any ideas here?
Thanks for your feedback!
Best regards,
Klaas.
