I read a lot of posts in this forum and still have problems to understand how to control the LED Strips with FIBARO RGBW Controller 2.
Could someone simply clarify how to control:
- Dimming for colours
- Dimming for white only
- Setting up simple colours: red, green, yellow, blue etc.
- Setting up colour mix. - How to control the colour with the colour controller?
I would appreciate step-wise approach like:
- For this operation use only these Items…
- To control white only make this
- Do not touch these items (read only, does not make sense)
I fight with all items an and I have a feeling they live their own life. I understood in RGB mode you can control each channel separately.
Item: switch_dimmer you can switch ON/OF and dim the light
Item: color_color you can pick up the color
(thought so because when I do this the LED Stripe does not react for the colour I choose.
What is the different between color and color1, dimmmer, dimmer1?
It makes me creasy.
In addition with every parameter change i receive this warning:
2024-03-03 18:49:09.174 [WARN ] [ternal.converter.ZWaveColorConverter] - No conversion in ZWaveColorConverter to StringType
My connection:
24V DC
2 x 5m RGBW LED Stripes in parallel
INx configured as operational mode 2 (monostable switch) - BUT NO SWITCHES CONNECTED physicaly
Parameter 150: checked RGB and HSB modes
My setup:
OH 4.1.0
RaspberryPi 4+
