It looks like I may be unexpectedly needing to replace my home water heater
I’m looking at a couple of them on HomeDepot and see that Rheem sells a decent unit that includes a ‘smart’ wifi module that you can get alerts if there is a leak, etc. Looks like they have an app in the android/ios markets and is already wink compatible.
Has anyone done something similar already? Perhaps a Rheem binding or other methods to get information to Openhab?
Mine is getting old, and I might be in the same boat as you at some point soon. Doing some searching it looks like you can access via web services at http://io.myrheem.com/#overview
I have a 80 gal heat pump hot water heater with wifi that I have yet to figure out how to integrate into openhab. It’s amazing how much info Rheem gives you on the water heater display, the problem I have is you can’t even get the temp of the water over the API.
