Hi all,
I’m looking for help again ![]()
I plan to install an invisble speaker inside of the wooden panels of my canopy.
Currently I’m using Echos for all TTS topics but I guess that won’t work for my planed scenario.
So let me explain some of my use cases:
- Speak to people at my door in case I’m not at home (postman, friends… intruders
) - Point 1 only makes sence if I’m able to hear what they say. So it’s needs a microphone which I need a live stream from.
- TTS - Like for example when I didn’t closed all windows it should alarm me as soon as I lock the frontdoor. I have a echo in my hall but when you are outside you dont really hear it.
- Play music for example when we are coming together with the neighbors
All above mentioned scenarios of course should be possible to handle in openhab.
For connection everything is possible:
Wifi
Ethernet Cable
KNX Bus
It doesnt need to be especially made for outdoor use because I can place it in a save spot in the canopy. But of course it would be better if its made for outdoor use.
Any suggestions for hardware and best software integration?
