I want to use the new rule UI to send the recivedCommand to another item, is this possible in the UI or must I write rules the old way?
You don’t have to write up the entire rule in text configuration. You can still set the rule up using the UI but for the rule action you will select Run Script
. Choose the script language you wish to use and that will open a small text editor where you can add the script lines you require (only the body of the rule, the triggers and conditions are taken care of by the UI setup).
Thanks, I try it out
