Yes ffmpeg can read and write h264.ts and mpeg2.ts as it is more about the contents of the file and not the container.
what format is provided by the backend?
if itās an regular video format a browser should support it
so itās just reading the stream and writing into a file (spin of a dedicated thread to make it asynchronous)
Iāll provide you the timezone code I use in the Shelly binding when getting home or tomorrow
Here we are:
- Get local time, timezone of the PC (systemDefault)
public static DateTimeType getTimestamp() {
return new DateTimeType(ZonedDateTime.ofInstant(Instant.ofEpochSecond(now()), ZoneId.systemDefault()));
- With given timezone
public static DateTimeType getTimestamp(String zone, long timestamp) {
ZoneId zoneId = ZoneId.of(zone);
ZonedDateTime zdt = LocalDateTime.now().atZone(zoneId);
int delta = zdt.getOffset().getTotalSeconds();
return new DateTimeType(ZonedDateTime.ofInstant(Instant.ofEpochSecond(timestamp - delta), zoneId));
This can be used if you are able to retrieve the timezone from the api service.
Reading a stream from a given URL
String imageUrl = SERVLET_IMAGE_URL_BASE + uri;
logger.debug("RachioImage: {} image '{}' from '{}'", request.getMethod(), uri, imageUrl);
setHeaders(resp);
URL url = new URL(imageUrl);
URLConnection conn = url.openConnection();
conn.setDoInput(true);
conn.setDoOutput(true);
reader = conn.getInputStream();
writer = resp.getOutputStream();
// read data in 4k chunks
byte[] data = new byte[4096];
int n;
while (((n = reader.read(data)) != -1)) {
writer.write(data, 0, n);
With the rachio binding I had a problem that their code service doesnāt set the correct content type. What I did was creating a servlet, which runs on the OH system and redirects the requested so I could fix the image type and return the browser the correct media type
The Api return the media url, which will be rewritten to point to the local system (127.0.0.1)
The rewritten url becomes the channel value
so the browser will open this one, which in fact generates a request to the bindingās servlet
inside the binding I load the remote media and sends it to the browser, which then display the correct media fule
In your case you could do something similar. Store the file in a sub folder under /html so itās accessible via http.
rewrite the url to point to that uri and update the channel with that value
the browser or other app opens this url, the binding catches the request and returns the file data to the client
some kind of round robin or timeline makes sure that your are not queuing endless video file
This is the servlet code: https://github.com/markus7017/org.openhab.binding.rachio/blob/master/src/main/java/org/openhab/binding/rachio/internal/api/RachioImageServlet.java
Awesome, thanks for the pointers. Some great ideas I hadnāt thought of for sure. The actual Ring video is mp4 and used to be able to be retrieved via simple wget, itās just new authentication that was getting in the way. Hopefully I can make some time in the next few days to bang on this for a bit and get something done, itās been an unusually busy time lately for some reason.
This should work the same way (in fact every format, which is supported by the browser/client app)
I would place the download folder somewhere under conf/html so you could rewrite the url with something like āhttp://127.0.0.1/static/<ring folder>/<filename>ā - keep the same file name, which should be unique.
fyi: there is also HttpUtil. downloadImage(), but Iām not sure if this also handled video files
I installed the ring binding 2.5.1 and have the same problem with a delay of about 30 to 60 seconds. Polling interval is set to 3 seconds. So i would expect to get an event after a ring notification with a max delay of 3 seconds and not 30 seconds. The delay is not caused by rule compilation. Using IFTTT i never had a delay but the service is not usable anymore with myopenhab cloud service.
I hope that anybody has a solution for this problem.
Did you set the polling delay on the device (doorbell, etc) thing, the account thing, or both?
I set the polling intervall on the device and account thing to 3 seconds. Location is Germany if this is relevant.
@markus7017 HttpUtil. downloadImage() unfortunately didnāt work, but your servlet idea seems to be bearing some fruit. I hope to have something up very soon with the video working via a servlet!
@fuslwusl I took a look at things and so far I donāt see anything in the binding that could be causing this, every time the poll interval is reached, it does a request to Ringās server and if there is a new event then it updates the channels. Unfortunately this means that we are at the mercy of the ring side to post the event in a timely manner on that interface. I suspect IFTTT didnāt have that issue because they might be using a subscription type connection to an interface instead of polling the rest interface. It may be part of the perks of being in their āpartnerā program if thatās the case. Unfortunately as soon as I replied to the email thread I had with them that I was finally able to connect and poll data and asked if there was any way we could discuss getting into their partner program, they went from timely responses to radio silence.
I will keep digging into it though to see if thereās something we can do once I get a release with the video link put out.
Thanx for checking this again. I really hope Ring will open their system for basic features like motion and ring notifications. Amazon Echo devices are able to get the ring notifications since a few weeks. Perhaps there is a way to get these notifications from there or from IFTTT? The best way was IFTTT for me. But openhab doesnāt support it anymore. So it would be great to get realtime events using this binding.
Iāve put a new version of the binding here: org.openhab.binding.ring-2.5.1-SNAPSHOT.jar . This one should fix the time zone and time formatting, and includes providing a link to the last event video again. The binding puts up a servlet that runs at http://:8080/ring/video/ to provide an .mp4 of the video and will put that url in the channel. Iāve also cleaned up the logging to not include sensitive information in debug (only trace). Hopefully this one works for everyone.
I am clearly confused as to how the servlet for the ring video is suppose to workā¦ do you have a walkthrough as to how it is set up? I have the URL showing as:
http://10.0.1.25:8080/ring/video/[Bunch of numbers here]
I put this URL in a browser and I get the play icon with a slash through it. I am at a loss, I just canāt seem to follow the documents that @markus7017 linked. I have a very limited knowledge base for coding.
~John
Whilst direct access is the holy grail, Iām getting an almost instantaneous doorbell press event into openHAB by using an Alexa routine.
Iāve exposed a āDoor Bellā Switch item to Alexa, and on the Doorbell event from Ring, Iām setting this openHAB Switch to ON. Iāve then set up a Rule that when the āDoor Bellā switch is set to ON, it plays ādoorbell.mp3ā via openHAB into my multi-room audio setup. The Switch item is then set to OFF a second later.
This actually starts playing the sound through openHAB quicker than my Ring Chime and Echo devices do!
Hey Zolakk,
Installed your lastest binding and it works along with the streaming video. What I canāt figure out is the file actually gets created in /ring/video folder for a split second and then it disappears. The reason I know this is because I have DropBox monitoring /ring/video folder and I see it trying to make a copy to the cloud when it happens but it actually doesnāt grab it because it disappears so quickly.
Where are you putting this .MP4 file once its dropped in the /ring/video folder?
Is there anyway you can leave it there so it can be referenced in the future?
If you can keep the file there; is it possible to add another field to the binding which is just the filename itself? This way I can reference the file name from a virtual web directory so I can play the video remotely from OH.
Keep up the great work!
Best, Jay
Clicking on URL after an hour
Hereās the dump I get when you click on a URL that existed an hour ago. Iām guessing Ring is not allowing the API to look at OLD videoās without their premium service which allows you to go back in time.
I did this a few times and the same dump occurs. May want to catch this exception and log it as Video No Longer Accessible.
2020-02-06 13:32:18.917 [ERROR] [nding.ring.internal.RingVideoServlet] - RingVideo: Unable to process request: null
2020-02-06 13:32:19.205 [ERROR] [hab.binding.ring.internal.RestClient] - Authentication exception in getRecordingURL
org.openhab.binding.ring.internal.errors.AuthenticationException: Invalid request
at org.openhab.binding.ring.internal.RestClient.getRequest(RestClient.java:222) ~[288:org.openhab.binding.ring:2.5.1.202002051924]
at org.openhab.binding.ring.internal.RestClient.getRecordingURL(RestClient.java:627) [288:org.openhab.binding.ring:2.5.1.202002051924]
at org.openhab.binding.ring.internal.RingVideoServlet.service(RingVideoServlet.java:90) [288:org.openhab.binding.ring:2.5.1.202002051924]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [29:javax.servlet-api:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [82:org.eclipse.jetty.security:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) [85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [186:org.ops4j.pax.web.pax-web-jetty:7.2.3]
at org.eclipse.jetty.server.Server.handle(Server.java:531) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
2020-02-06 13:32:19.207 [ERROR] [nding.ring.internal.RingVideoServlet] - RingVideo: Unable to process request: null
Best, Jay
The binding doesnāt put an mp4 file anywhere that iām aware of, perhaps in a temp directory somewhere. All it does is take that long string of numbers (the āding idā as they put it) and adds the requisite authentication token, etc which is needed for every request and streams that out to the browser. You are also correct with your follow up post, IIRC if you donāt have the premium service, they donāt save any videos at all on their end and after that one link expires itās gone forever. It seems the only way to get video working reliably is to also be signed up for their premium service that I have experienced.
As far as responsiveness, iāve found the same that @Confused did (I suspect also because itās a āpartnerā situation, they get the luxury of a push interface) and thatās actually the approach I currently use myself because it so much more responsive and it integrates with my Alexas more directly. Ring still has not yet replied to me on getting a āpartner likeā situation set up or even any formal documentation, but initially they did say something along the lines of that because this is an open source project getting issued a partner ID (and thus access to partner APIs and documentation) was not possible because that ID would have to be published and so they wouldnāt be able to control it.
@zolakk,
I installed the binding and everything appears to be working except for the video. I have the premium service and have not enabled two factor authentication yet. I am not getting the video, when I try to open the URL in a new tab, my log shows:
2020-02-07 06:16:52.386 [ERROR] [nding.ring.internal.RingVideoServlet] - RingVideo: Unable to process request: null
2020-02-07 06:29:23.683 [ERROR] [hab.binding.ring.internal.RestClient] - Authentication exception in getRecordingURL
at org.openhab.binding.ring.internal.RestClient.getRequest(RestClient.java:222) ~[bundleFile:?]
at org.openhab.binding.ring.internal.RestClient.getRecordingURL(RestClient.java:627) [bundleFile:?]
at org.openhab.binding.ring.internal.RingVideoServlet.service(RingVideoServlet.java:90) [bundleFile:?]
When I try to wget the video from the URL, I get a file, but it is 0 kb in size. Any help would be appreciated.
~John
EDIT - to add more of the error
Suddeny tonight im getting āOFFLINE - COMMUNICATION_ERROR Initialization failed: nullā under the ring account binding?
EDIT never mind - for some reason my server got an IPV6 address and my homeplugs dont like that. :-/
Also i cant get the link to work (cannot click it in the habpanel dummy widget) also when copied from the paperui to a new tab noting is displayed.
i have gotten this to work now but when an event is triggereed the video changes but does not lay until i refresh the habpanel. its like the video is getting pulled to fast, before my ring account has had a chance to create the video?
