Hi
I got the Roidmi Eva vacum + mop robot (not the EVE). I found it via the MI IO binding and ran the “Execute test to find supported channels” feature. The result is below. It seems somehow not to support many channels:
2022-07-31 19:39:37.008 [INFO ] [ernal.handler.MiIoUnsupportedHandler] - Info for roidmi.vacuum.v66
*Properties: battery → 13, pm25 → 14, co2e → 15, tvoc → 16, humidity → 17, temperature → 18, co2 → 19, bt_gateway_status → 20, /device/get_bledevice_by_gateway → 21, power → 22, wifi_led → 23, usb_on → 24, on → 25, OnOff_State → 26, Humidifier_Gear → 27, Humidity_Value → 28, HumiSet_Value → 29, Led_State → 30, TipSound_State → 31, watertankstatus → 32, wet_and_protect → 33, mode → 34, ptc_on → 35, ptc_status → 36, display → 37, child_lock → 38, sound → 39, control_speed → 40, favourite_speed → 41, temperature_outside → 42, filter_rate → 43, filter_day → 44, ptc_level → 45, screen_direction → 46, filter_intermediate → 47, filter_inter_day → 48, filter_efficient → 49, filter_effi_day → 50, roll → 51, roll_angle → 52, timer_off → 53, beep_sound → 54, light → 55, speed → 56, doorbell_volume → 57, gateway_volume → 58, alarming_volume → 59, doorbell_push → 60, get_arming → 61, corridor_light → 62, night_light_rgb → 63, rgb → 64, get_arming_time → 65, corridor_on_time → 66, get_device_prop[“lumi.0”,“gateway_lang”] → 67, get_zigbee_channel → 68, get_lumi_bind → 69, dry → 70, led → 71, motor → 72, drytime → 73, airer_location → 74, disinfect → 75, distime → 76, on_off → 77, auto → 78, fan_speed → 79, buzzer → 80, temp → 81, tank_full → 82, compressor_status → 83, defrost_status → 84, fan_st → 85, alarm → 86, bright → 87, cct → 88, snm → 89, dv → 90, sw → 91, bl → 92, ms → 93, ac → 94, mb → 95, cid → 96, get_switch_en → 97, scene_num → 98, pow → 99, flm → 100, ambstatus → 101, ambvalue → 102, dvalue → 103, eyecare → 104, power_consume_rate → 105, voltage → 106, power_price → 107, power_factor → 108, current → 109, elec_leakage → 110, switch1 → 111, switchname1 → 112, switch2 → 113, switchname2 → 114, switch3 → 115, switchname3 → 116, true → 117, run_state → 118, err_state → 119, battary_life → 120, box_type → 121, mop_type → 122, mop_route → 123, s_time → 124, s_area → 125, suction_grade → 126, water_grade → 127, remember_map → 128, has_map → 129, is_mop → 130, has_newmap → 131, washStatus → 132, velocity → 133, waterTemp → 134, targetTemp → 135, errStatus → 136, hotWater → 137, needClean → 138, modeType → 139, appointStart → 140, appointEnd → 141, seat_temp → 142, status_seatheat → 143, water_temp_t → 144, fan_temp → 145, status_led → 146, bh_mode → 147, delayoff → 148, nl_br → 149, ct → 150, color_mode → 151, flowing → 152, name → 153, bg_bright → 154, bg_power → 155, bg_rgb → 156, bg_ct → 157, bg_lmode → 158, run_status → 159, rinse → 160, tds_in → 161, tds_out → 162, f1_totalflow → 163, f1_totaltime → 164, f1_usedflow → 165, f1_usedtime → 166, f2_totalflow → 167, f2_totaltime → 168, f2_usedflow → 169, f2_usedtime → 170, f3_totalflow → 171, f3_totaltime → 172, f3_usedflow → 173, f3_usedtime → 174, f4_totalflow → 175, f4_totaltime → 176, f4_usedflow → 177, f4_usedtime → 178, maintenance_state → 179, maintenance_interval → 180, tds_warn_thd → 181, tds_out_avg → 182, lightMode → 183, ptc_state → 184, aqi → 185, average_aqi → 186, f1_hour_used → 187, use_time → 188, motor1_speed → 189, led_level → 190, temp_dec → 191, usb_state → 192, time_state → 193, night_state → 194, night_beg_time → 195, night_end_time → 196, f1_hour → 197, filter1_life → 198, favorite_level → 199, purify_volume → 200, volume → 201, motor2_speed → 202, angle_enable → 203, angle → 204, poweroff_time → 205, led_b → 206, speed_level → 207, natural_level → 208, ac_power → 209, bat_charge → 210, target_temperature → 211, brightness → 212, relative_humidity → 213, theqmostat → 214, limit_hum → 215, trans_level → 216, depth → 217, lp_autooff → 218, lp_autooff_delay → 219, lp_threshold → 220, *
{“life”:181225,“model”:“roidmi.vacuum.v66”,“miio_ver”:“0.0.7”,“fw_ver”:“1.0.3_3217”,“VmPeak”:46752,“VmRSS”:1536,“MemFree”:18160,“netif”:{“localIp”:“”,“mask”:“255.255.255.0”,“gw”:“xx.xx.xx.xx”},“miio_times”:[181225,10,0,181214]}
{“id”:12,“method”:“miIO.info”,“params”:[]} → {“id”:12,“result”:{“life”:181225,“model”:“roidmi.vacuum.v66”,“miio_ver”:“0.0.7”,“fw_ver”:“1.0.3_3217”,“VmPeak”:46752,“VmRSS”:1536,“MemFree”:18160,“netif”:{“localIp”:“xx.xx.xx.xx”,“mask”:“255.255.255.0”,“gw”:“xx.xx.xx.xx”},“miio_times”:[181225,10,0,181214]}}
{“id”:13,“method”:“get_prop”,“params”:[“battery”]} → {“id”:13,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:14,“method”:“get_prop”,“params”:[“pm25”]} → {“id”:14,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:15,“method”:“get_prop”,“params”:[“co2e”]} → {“id”:15,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:16,“method”:“get_prop”,“params”:[“tvoc”]} → {“id”:16,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:17,“method”:“get_prop”,“params”:[“humidity”]} → {“id”:17,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:18,“method”:“get_prop”,“params”:[“temperature”]} → {“id”:18,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:19,“method”:“get_prop”,“params”:[“co2”]} → {“id”:19,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:20,“method”:“bt_gateway_status”,“params”:[]} → {“id”:20,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:21,“method”:“/device/get_bledevice_by_gateway”,“params”:[]} → {“id”:21,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:22,“method”:“get_prop”,“params”:[“power”]} → {“id”:22,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:23,“method”:“get_prop”,“params”:[“wifi_led”]} → {“id”:23,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:24,“method”:“get_prop”,“params”:[“usb_on”]} → {“id”:24,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:25,“method”:“get_prop”,“params”:[“on”]} → {“id”:25,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:26,“method”:“get_prop”,“params”:[“OnOff_State”]} → {“id”:26,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:27,“method”:“get_prop”,“params”:[“Humidifier_Gear”]} → {“id”:27,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:28,“method”:“get_prop”,“params”:[“Humidity_Value”]} → {“id”:28,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:29,“method”:“get_prop”,“params”:[“HumiSet_Value”]} → {“id”:29,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:30,“method”:“get_prop”,“params”:[“Led_State”]} → {“id”:30,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:31,“method”:“get_prop”,“params”:[“TipSound_State”]} → {“id”:31,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:32,“method”:“get_prop”,“params”:[“watertankstatus”]} → {“id”:32,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:33,“method”:“get_prop”,“params”:[“wet_and_protect”]} → {“id”:33,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:34,“method”:“get_prop”,“params”:[“mode”]} → {“id”:34,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:35,“method”:“get_prop”,“params”:[“ptc_on”]} → {“id”:35,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:36,“method”:“get_prop”,“params”:[“ptc_status”]} → {“id”:36,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:37,“method”:“get_prop”,“params”:[“display”]} → {“id”:37,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:38,“method”:“get_prop”,“params”:[“child_lock”]} → {“id”:38,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:39,“method”:“get_prop”,“params”:[“sound”]} → {“id”:39,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:40,“method”:“get_prop”,“params”:[“control_speed”]} → {“id”:40,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:41,“method”:“get_prop”,“params”:[“favourite_speed”]} → {“id”:41,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:42,“method”:“get_prop”,“params”:[“temperature_outside”]} → {“id”:42,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:43,“method”:“get_prop”,“params”:[“filter_rate”]} → {“id”:43,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:44,“method”:“get_prop”,“params”:[“filter_day”]} → {“id”:44,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:45,“method”:“get_prop”,“params”:[“ptc_level”]} → {“id”:45,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:46,“method”:“get_prop”,“params”:[“screen_direction”]} → {“id”:46,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:47,“method”:“get_prop”,“params”:[“filter_intermediate”]} → {“id”:47,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:48,“method”:“get_prop”,“params”:[“filter_inter_day”]} → {“id”:48,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:49,“method”:“get_prop”,“params”:[“filter_efficient”]} → {“id”:49,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:50,“method”:“get_prop”,“params”:[“filter_effi_day”]} → {“id”:50,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:51,“method”:“get_prop”,“params”:[“roll”]} → {“id”:51,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:52,“method”:“get_prop”,“params”:[“roll_angle”]} → {“id”:52,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:53,“method”:“get_prop”,“params”:[“timer_off”]} → {“id”:53,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:54,“method”:“get_prop”,“params”:[“beep_sound”]} → {“id”:54,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:55,“method”:“get_prop”,“params”:[“light”]} → {“id”:55,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:56,“method”:“get_prop”,“params”:[“speed”]} → {“id”:56,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:57,“method”:“get_prop”,“params”:[“doorbell_volume”]} → {“id”:57,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:58,“method”:“get_prop”,“params”:[“gateway_volume”]} → {“id”:58,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:59,“method”:“get_prop”,“params”:[“alarming_volume”]} → {“id”:59,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:60,“method”:“get_prop”,“params”:[“doorbell_push”]} → {“id”:60,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:61,“method”:“get_arming”,“params”:[]} → {“id”:61,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:62,“method”:“get_prop”,“params”:[“corridor_light”]} → {“id”:62,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:63,“method”:“get_prop”,“params”:[“night_light_rgb”]} → {“id”:63,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:64,“method”:“get_prop”,“params”:[“rgb”]} → {“id”:64,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:65,“method”:“get_arming_time”,“params”:[]} → {“id”:65,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:66,“method”:“get_prop”,“params”:[“corridor_on_time”]} → {“id”:66,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:67,“method”:“get_device_prop”,“params”:[“lumi.0”,“gateway_lang”]} → {“id”:67,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:68,“method”:“get_zigbee_channel”,“params”:[]} → {“id”:68,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:69,“method”:“get_lumi_bind”,“params”:[]} → {“id”:69,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:70,“method”:“get_prop”,“params”:[“dry”]} → {“id”:70,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:71,“method”:“get_prop”,“params”:[“led”]} → {“id”:71,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:72,“method”:“get_prop”,“params”:[“motor”]} → {“id”:72,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:73,“method”:“get_prop”,“params”:[“drytime”]} → {“id”:73,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:74,“method”:“get_prop”,“params”:[“airer_location”]} → {“id”:74,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:75,“method”:“get_prop”,“params”:[“disinfect”]} → {“id”:75,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:76,“method”:“get_prop”,“params”:[“distime”]} → {“id”:76,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:77,“method”:“get_prop”,“params”:[“on_off”]} → {“id”:77,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:78,“method”:“get_prop”,“params”:[“auto”]} → {“id”:78,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:79,“method”:“get_prop”,“params”:[“fan_speed”]} → {“id”:79,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:80,“method”:“get_prop”,“params”:[“buzzer”]} → {“id”:80,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:81,“method”:“get_prop”,“params”:[“temp”]} → {“id”:81,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:82,“method”:“get_prop”,“params”:[“tank_full”]} → {“id”:82,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:83,“method”:“get_prop”,“params”:[“compressor_status”]} → {“id”:83,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:84,“method”:“get_prop”,“params”:[“defrost_status”]} → {“id”:84,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:85,“method”:“get_prop”,“params”:[“fan_st”]} → {“id”:85,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:86,“method”:“get_prop”,“params”:[“alarm”]} → {“id”:86,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:87,“method”:“get_prop”,“params”:[“bright”]} → {“id”:87,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:88,“method”:“get_prop”,“params”:[“cct”]} → {“id”:88,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:89,“method”:“get_prop”,“params”:[“snm”]} → {“id”:89,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:90,“method”:“get_prop”,“params”:[“dv”]} → {“id”:90,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:91,“method”:“get_prop”,“params”:[“sw”]} → {“id”:91,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:92,“method”:“get_prop”,“params”:[“bl”]} → {“id”:92,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:93,“method”:“get_prop”,“params”:[“ms”]} → {“id”:93,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:94,“method”:“get_prop”,“params”:[“ac”]} → {“id”:94,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:95,“method”:“get_prop”,“params”:[“mb”]} → {“id”:95,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:96,“method”:“get_prop”,“params”:[“cid”]} → {“id”:96,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:97,“method”:“get_prop”,“params”:[“get_switch_en”]} → {“id”:97,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:98,“method”:“get_prop”,“params”:[“scene_num”]} → {“id”:98,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:99,“method”:“get_prop”,“params”:[“pow”]} → {“id”:99,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:100,“method”:“get_prop”,“params”:[“flm”]} → {“id”:100,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:101,“method”:“get_prop”,“params”:[“ambstatus”]} → {“id”:101,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:102,“method”:“get_prop”,“params”:[“ambvalue”]} → {“id”:102,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:103,“method”:“get_prop”,“params”:[“dvalue”]} → {“id”:103,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:104,“method”:“get_prop”,“params”:[“eyecare”]} → {“id”:104,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:105,“method”:“get_prop”,“params”:[“power_consume_rate”]} → {“id”:105,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:106,“method”:“get_prop”,“params”:[“voltage”]} → {“id”:106,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:107,“method”:“get_prop”,“params”:[“power_price”]} → {“id”:107,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:108,“method”:“get_prop”,“params”:[“power_factor”]} → {“id”:108,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:109,“method”:“get_prop”,“params”:[“current”]} → {“id”:109,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:110,“method”:“get_prop”,“params”:[“elec_leakage”]} → {“id”:110,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:111,“method”:“get_prop”,“params”:[“switch1”]} → {“id”:111,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:112,“method”:“get_prop”,“params”:[“switchname1”]} → {“id”:112,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:113,“method”:“get_prop”,“params”:[“switch2”]} → {“id”:113,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:114,“method”:“get_prop”,“params”:[“switchname2”]} → {“id”:114,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:115,“method”:“get_prop”,“params”:[“switch3”]} → {“id”:115,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:116,“method”:“get_prop”,“params”:[“switchname3”]} → {“id”:116,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:117,“method”:“true”,“params”:[]} → {“id”:117,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:118,“method”:“get_prop”,“params”:[“run_state”]} → {“id”:118,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:119,“method”:“get_prop”,“params”:[“err_state”]} → {“id”:119,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:120,“method”:“get_prop”,“params”:[“battary_life”]} → {“id”:120,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:121,“method”:“get_prop”,“params”:[“box_type”]} → {“id”:121,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:122,“method”:“get_prop”,“params”:[“mop_type”]} → {“id”:122,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:123,“method”:“get_prop”,“params”:[“mop_route”]} → {“id”:123,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:124,“method”:“get_prop”,“params”:[“s_time”]} → {“id”:124,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:125,“method”:“get_prop”,“params”:[“s_area”]} → {“id”:125,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:126,“method”:“get_prop”,“params”:[“suction_grade”]} → {“id”:126,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:127,“method”:“get_prop”,“params”:[“water_grade”]} → {“id”:127,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:128,“method”:“get_prop”,“params”:[“remember_map”]} → {“id”:128,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:129,“method”:“get_prop”,“params”:[“has_map”]} → {“id”:129,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:130,“method”:“get_prop”,“params”:[“is_mop”]} → {“id”:130,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:131,“method”:“get_prop”,“params”:[“has_newmap”]} → {“id”:131,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:132,“method”:“get_prop”,“params”:[“washStatus”]} → {“id”:132,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:133,“method”:“get_prop”,“params”:[“velocity”]} → {“id”:133,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:134,“method”:“get_prop”,“params”:[“waterTemp”]} → {“id”:134,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:135,“method”:“get_prop”,“params”:[“targetTemp”]} → {“id”:135,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:136,“method”:“get_prop”,“params”:[“errStatus”]} → {“id”:136,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:137,“method”:“get_prop”,“params”:[“hotWater”]} → {“id”:137,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:138,“method”:“get_prop”,“params”:[“needClean”]} → {“id”:138,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:139,“method”:“get_prop”,“params”:[“modeType”]} → {“id”:139,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:140,“method”:“get_prop”,“params”:[“appointStart”]} → {“id”:140,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:141,“method”:“get_prop”,“params”:[“appointEnd”]} → {“id”:141,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:142,“method”:“get_prop”,“params”:[“seat_temp”]} → {“id”:142,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:143,“method”:“get_prop”,“params”:[“status_seatheat”]} → {“id”:143,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:144,“method”:“get_prop”,“params”:[“water_temp_t”]} → {“id”:144,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:145,“method”:“get_prop”,“params”:[“fan_temp”]} → {“id”:145,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:146,“method”:“get_prop”,“params”:[“status_led”]} → {“id”:146,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:147,“method”:“get_prop”,“params”:[“bh_mode”]} → {“id”:147,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:148,“method”:“get_prop”,“params”:[“delayoff”]} → {“id”:148,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:149,“method”:“get_prop”,“params”:[“nl_br”]} → {“id”:149,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:150,“method”:“get_prop”,“params”:[“ct”]} → {“id”:150,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:151,“method”:“get_prop”,“params”:[“color_mode”]} → {“id”:151,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:152,“method”:“get_prop”,“params”:[“flowing”]} → {“id”:152,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:153,“method”:“get_prop”,“params”:[“name”]} → {“id”:153,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:154,“method”:“get_prop”,“params”:[“bg_bright”]} → {“id”:154,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:155,“method”:“get_prop”,“params”:[“bg_power”]} → {“id”:155,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:156,“method”:“get_prop”,“params”:[“bg_rgb”]} → {“id”:156,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:157,“method”:“get_prop”,“params”:[“bg_ct”]} → {“id”:157,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:158,“method”:“get_prop”,“params”:[“bg_lmode”]} → {“id”:158,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:159,“method”:“get_prop”,“params”:[“run_status”]} → {“id”:159,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:160,“method”:“get_prop”,“params”:[“rinse”]} → {“id”:160,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:161,“method”:“get_prop”,“params”:[“tds_in”]} → {“id”:161,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:162,“method”:“get_prop”,“params”:[“tds_out”]} → {“id”:162,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:163,“method”:“get_prop”,“params”:[“f1_totalflow”]} → {“id”:163,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:164,“method”:“get_prop”,“params”:[“f1_totaltime”]} → {“id”:164,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:165,“method”:“get_prop”,“params”:[“f1_usedflow”]} → {“id”:165,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:166,“method”:“get_prop”,“params”:[“f1_usedtime”]} → {“id”:166,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:167,“method”:“get_prop”,“params”:[“f2_totalflow”]} → {“id”:167,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:168,“method”:“get_prop”,“params”:[“f2_totaltime”]} → {“id”:168,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:169,“method”:“get_prop”,“params”:[“f2_usedflow”]} → {“id”:169,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:170,“method”:“get_prop”,“params”:[“f2_usedtime”]} → {“id”:170,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:171,“method”:“get_prop”,“params”:[“f3_totalflow”]} → {“id”:171,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:172,“method”:“get_prop”,“params”:[“f3_totaltime”]} → {“id”:172,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:173,“method”:“get_prop”,“params”:[“f3_usedflow”]} → {“id”:173,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:174,“method”:“get_prop”,“params”:[“f3_usedtime”]} → {“id”:174,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:175,“method”:“get_prop”,“params”:[“f4_totalflow”]} → {“id”:175,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:176,“method”:“get_prop”,“params”:[“f4_totaltime”]} → {“id”:176,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:177,“method”:“get_prop”,“params”:[“f4_usedflow”]} → {“id”:177,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:178,“method”:“get_prop”,“params”:[“f4_usedtime”]} → {“id”:178,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:179,“method”:“get_prop”,“params”:[“maintenance_state”]} → {“id”:179,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:180,“method”:“get_prop”,“params”:[“maintenance_interval”]} → {“id”:180,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:181,“method”:“get_prop”,“params”:[“tds_warn_thd”]} → {“id”:181,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:182,“method”:“get_prop”,“params”:[“tds_out_avg”]} → {“id”:182,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:183,“method”:“get_prop”,“params”:[“lightMode”]} → {“id”:183,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:184,“method”:“get_prop”,“params”:[“ptc_state”]} → {“id”:184,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:185,“method”:“get_prop”,“params”:[“aqi”]} → {“id”:185,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:186,“method”:“get_prop”,“params”:[“average_aqi”]} → {“id”:186,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:187,“method”:“get_prop”,“params”:[“f1_hour_used”]} → {“id”:187,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:188,“method”:“get_prop”,“params”:[“use_time”]} → {“id”:188,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:189,“method”:“get_prop”,“params”:[“motor1_speed”]} → {“id”:189,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:190,“method”:“get_prop”,“params”:[“led_level”]} → {“id”:190,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:191,“method”:“get_prop”,“params”:[“temp_dec”]} → {“id”:191,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:192,“method”:“get_prop”,“params”:[“usb_state”]} → {“id”:192,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:193,“method”:“get_prop”,“params”:[“time_state”]} → {“id”:193,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:194,“method”:“get_prop”,“params”:[“night_state”]} → {“id”:194,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:195,“method”:“get_prop”,“params”:[“night_beg_time”]} → {“id”:195,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:196,“method”:“get_prop”,“params”:[“night_end_time”]} → {“id”:196,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:197,“method”:“get_prop”,“params”:[“f1_hour”]} → {“id”:197,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:198,“method”:“get_prop”,“params”:[“filter1_life”]} → {“id”:198,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:199,“method”:“get_prop”,“params”:[“favorite_level”]} → {“id”:199,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:200,“method”:“get_prop”,“params”:[“purify_volume”]} → {“id”:200,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:201,“method”:“get_prop”,“params”:[“volume”]} → {“id”:201,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:202,“method”:“get_prop”,“params”:[“motor2_speed”]} → {“id”:202,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:203,“method”:“get_prop”,“params”:[“angle_enable”]} → {“id”:203,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:204,“method”:“get_prop”,“params”:[“angle”]} → {“id”:204,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:205,“method”:“get_prop”,“params”:[“poweroff_time”]} → {“id”:205,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:206,“method”:“get_prop”,“params”:[“led_b”]} → {“id”:206,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:207,“method”:“get_prop”,“params”:[“speed_level”]} → {“id”:207,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:208,“method”:“get_prop”,“params”:[“natural_level”]} → {“id”:208,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:209,“method”:“get_prop”,“params”:[“ac_power”]} → {“id”:209,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:210,“method”:“get_prop”,“params”:[“bat_charge”]} → {“id”:210,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:211,“method”:“get_prop”,“params”:[“target_temperature”]} → {“id”:211,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:212,“method”:“get_prop”,“params”:[“brightness”]} → {“id”:212,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:213,“method”:“get_prop”,“params”:[“relative_humidity”]} → {“id”:213,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:214,“method”:“get_prop”,“params”:[“theqmostat”]} → {“id”:214,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:215,“method”:“get_prop”,“params”:[“limit_hum”]} → {“id”:215,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:216,“method”:“get_prop”,“params”:[“trans_level”]} → {“id”:216,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:217,“method”:“get_prop”,“params”:[“depth”]} → {“id”:217,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:218,“method”:“get_prop”,“params”:[“lp_autooff”]} → {“id”:218,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:219,“method”:“get_prop”,“params”:[“lp_autooff_delay”]} → {“id”:219,“error”:{“code”:-9999,“message”:“user ack timeout”}}
{“id”:220,“method”:“get_prop”,“params”:[“lp_threshold”]} → {“id”:220,“error”:{“code”:-9999,“message”:“user ack timeout”}}
Responsive properties
Device Info: {“life”:181225,“model”:“roidmi.vacuum.v66”,“miio_ver”:“0.0.7”,“fw_ver”:“1.0.3_3217”,“VmPeak”:46752,“VmRSS”:1536,“MemFree”:18160,“netif”:{“localIp”:“xx.xx.xx.xx”,“mask”:“255.255.255.0”,“gw”:“xx.xx.xx.xx”},“miio_times”:[181225,10,0,181214]}
0 channels with responses.
No supported channels found.
Device testing file saved to: /var/lib/openhab/miio/test-roidmi.vacuum.v66-20220731-193937.txt
Please share your these files on the community forum or github to get this device supported.
