I have an issue with roller shutter controller PAN08.
I installed it physically correct (I am able to control shutter by switches attached to controller) but in the openHab binded shutter is marked as Unknown Device. I have some properties visible and online but there is no channels accessible.
I run it on Raspberry Pi + openhabian + Z-Wave Z-Stick Gen5 ZW090.
I have seen some comments that full binding may take longer (specially for battery powered devices) but it is not a case. And shutter controller is binded for more than 12 hours now.
and I am new to it, so please have marcy
Thanks in advance
Read the manual for your device. Often the wake-up procedure is the same as the pairing procedure (e.g. for the ZCombo Smoke/CO Alarm one slides the battery out then back in while holding a button to pair it with the controller and to wake it up).
It takes a long time because battery powered devices often only communicate once or twice a day under normal circumstances. Transmitting over radio takes a lot of power. If they communicated more often you’d have to change the batteries every couple of days.
From the list of properties, the device has initialised ok, so it has woken up enough. Your device has just been added to the database in the past couple of days, so make sure you’re running the latest snapshot and hopefully it will work ok.
Well, a snapshot is the latest code - it’s not a released version but I’m not sure if I’d call it “unstable”. As per the docs, there are always the two ways to install (ie release and snapshot)…
So you will never be able to run a new version then…
I would suggest that instead, you should try and find what’s wrong - it won’t fix itself and it will just be there next time as there is very little changes these days.
Well, if you have a problem with this version, then it will still be there in the next version since the next release will be the same as this snapshot.
