micware
(Michiel)
February 12, 2017, 8:33pm
1
I installed 2.0 RFXCOM binding on openhab2
I can control my somfy motor with paper UI control
Now I want to put a up/down and stop button on my site map
I can not vind any examples or information about this on the forum
Is there a kind of Roller Shutter item (element) with UP Down and Stop button?
Any idee?
sihui
(SiHui)
February 12, 2017, 9:22pm
3
… and don’t forget to take a look into the docs:
http://docs.openhab.org/configuration/sitemaps.html
micware
(Michiel)
February 12, 2017, 9:32pm
4
Thank you
I used the shutter channel i found in paper UI “E1Somfy_Shutter”
Rollershutter rolluik "Rolluik [%.0f %%]" <rollershutter> {channel="E1Somfy_Shutter"}
Renamed the item to “rolluik”
Default item=rolluik
It shows on my site map, but it did not react when i press a button
Will look at it tomorrow, maybe I made a typo!
micware
(Michiel)
February 13, 2017, 9:12pm
6
Thanks for your help Christoph,
Its working now
I understand your comment about the channel name.
In paper UI I create my own channels, easier to remember for me
pmknowles
(Philip Knowles)
October 21, 2020, 10:25am
7
I know this is an old post but the question was “Rollershutter item on sitemap?” There is no mention of rollershutters in the link - it seems strange that there is a rollershutter item but not a corresponding way of implementing in a sitemap.
sihui
(SiHui)
October 21, 2020, 10:36am
8
Just put a switch on your sitemap:
Switch item=YourRollershutterItem
rossko57
(Rossko57)
October 21, 2020, 10:39am
9
There is also a Dimmer type Item, and no dimmer type widget.
Yes, there is no Rollershutter widget in sitemaps.
The Switch widget should recognize when a Rollershutter type Item is called, and render shutter buttons.
A Group would need characterizing as a Rollershutter type Group.
If your rollershutter is capable of proprtional positioning, you could use a Slider widget. You have choices.
micware
(Michiel)
October 21, 2020, 11:25am
10
I use “Default item= item_name” without problems on my sitemap
pmknowles
(Philip Knowles)
October 21, 2020, 11:29am
11
Thank you. I found that out separately but just posting a link to a page which doesn’t have that information is not helpful.
sihui
(SiHui)
October 21, 2020, 11:31am
12
I am sure you will invest more time to explain everything in detail in your future support answers.
