Rollershutter item with no STOP button?
Is it possible to configure a Rollershutter item, so that it has only the UP- and DOWN-button, no STOP-button?
Regards
Bernd
You can configure a Switch widget with mappings=[ ] so that you get two buttons to name what you like.
Hello, thanks for your help.
I know how to use a switch with two button, but how do I make the UP- and DOWN-Arrow on the button, like the rollershutter item does?
Switch item=RS_LIVING1 icon="rollershutter" mappings=[UP="up", DOWN="down"]
I wanted to use the Rollershutter item, because it has the UP- and Down-Arrow out-of-the-box…
You might be able to label your sitemap buttons with unicode symbols, it’s a bit viewer dependent.
