You can also ckeck this blog:
Rollershutter control through MQTT with item, sitemap and rule example.
Beta 1.4 is released! For more information, check the official Facebookgroup.
This item works like a charm:
Rollershutter Wohnzimmer_Rolladen_Tuer "Wohnzimmertür" (gWohnzimmer) {mqtt=">[mqttBroker:shellies/shellyswitch-32B62F/roller/0/command:command:*:MAP(shelly.map)], <[mqttBroker:shellies/shellyswitch-32B62F/roller/0/pos:state:default]"}
Only one thing:
In Basic UI the icon show that the shutter is closed when its opened and if its opened it shows closed. can i switch it?
Yes you can switch it. Use a map for the inbound topic.
