Since few days, the Rollershutter widget in the Hadroid app look broken in the Openhab2 snapshots.
They appear as basic Switch and send ON/OFF command on the event bus.
I get same error even with dummy rollershutter item defined without any binding.
In the log file, i get :
“Received HTTP POST request at ‘items/Shutter4’ with an invalid status value ‘ON’.”
My setup is Raspberry pi with almost all items defined in conf files.
Just updated to latest snapshot, exact same problem.
Basicui is working fine but Habdroid stills display rollershutter as switch and sends ON/OFF command on the event bus.
My Shutters are defined as Rollershutter in my shutters.items
Rollershutter Shutter_GF_Living_Side_Small "Seite klein [%d %%]" <rollershutter> (GF_Living,Shutters)
They are referenced as Switch in my sitemap
Switch item=Shutter_GF_Living_Terrace_Window
After reading the docs i’m unsure if this is valid (but it has worked ever since …)
If I define the shutters as slider or setpoint in the sitemap, they are rendered identical ok in HABDroid and in the WEBIf.
But defining the shutter-control as setpoint has the drawback, that the middle “Stop”-Button is missing then.
Me too
But I agree that what the Basic UI does in this case is definitely better than what HABDroid does. I really wonder if this was ever working differently in HABDroid, I very much doubt it. But feel free to enter an issue at GitHub · Where software is built about improving HABDroid to render it in the same way as Basic UI does.
I’m running into the exact same issue.
Rollershutters in combination with Habdroid on OH1 rendered fine.. in my OH2 setup (build 460) they are rendered as switched and send out invalid commands (ON/OFF) to OH2.
