i have some problems with my new openHab2 installation. Its all Brand new. I can pair my HM devices with the homegear. after that i installed java 8 and openhab2. if i want start oh i just geht the following error:
root@homegearpi:/var/log# sudo systemctl status openhab2.service
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
Active: deactivating (stop) (Result: exit-code) since Sa 2017-02-18 23:44:34 UTC; 1s ago
Docs: http://docs.openhab.org
https://community.openhab.org
Process: 7604 ExecStart=/usr/share/openhab2/start.sh server (code=exited, status=254)
Main PID: 7604 (code=exited, status=254); : 7762 (karaf)
CGroup: /system.slice/openhab2.service
└─control
├─7762 /bin/bash /usr/share/openhab2/runtime/bin/karaf stop
├─7887 /bin/bash /usr/share/openhab2/runtime/bin/karaf stop
├─7888 /usr/lib/jvm/java-8-oracle/jre/bin/java -version
├─7889 grep -E "([0-9].[0-9]\..*[0-9]).*"
├─7890 awk {print substr($3,2,length($3)-2)}
├─7891 awk {print substr($1, 3, 3)}
└─7892 sed -e s;\.;;g
Feb 18 23:44:34 homegearpi start.sh[7604]: null
Feb 18 23:44:34 homegearpi start.sh[7604]: Error occurred shutting down framework: java.lang.NumberFormatException: null
Feb 18 23:44:34 homegearpi start.sh[7604]: java.lang.NumberFormatException: null
Feb 18 23:44:34 homegearpi start.sh[7604]: at java.lang.Integer.parseInt(Integer.java:542)
Feb 18 23:44:34 homegearpi start.sh[7604]: at java.lang.Integer.parseInt(Integer.java:615)
Feb 18 23:44:34 homegearpi start.sh[7604]: at org.apache.karaf.main.ConfigProperties.<init>(ConfigProperties.java:208)
Feb 18 23:44:34 homegearpi start.sh[7604]: at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:226)
Feb 18 23:44:34 homegearpi start.sh[7604]: at org.apache.karaf.main.Main.main(Main.java:191)
Feb 18 23:44:34 homegearpi systemd[1]: openhab2.service: main process exited, code=exited, status=254/n/a
Feb 18 23:44:34 homegearpi stop[7762]: stop: Ignoring predefined value for KARAF_HOME
PS: I Use the opengear raspbian jessie. this is a read-only os. i think it is a permission error, but i have no ideo how i could fix it.
i hope you can help me
