RPi 3 install fails
HI, RPi 3 out the box installing flashed openhabianpi-raspbian-201706161358-git7ff273e-crc00389b9f.img.xz
fails. Card is fine. Failure is at installing node.js. Any ideas/hints?
I have manually installed node,js. Is there a list of the installs/config required to complete an installation anywhere?le the install’s running all I could do was monitor
Edit - finally got a clean install after 3 attempts.
