I’d like to run OpenHabian w/ persistence and lots of data logging off of a Raspberry Pi 3. It seems to make sense to use the USB boot mode rather than run off SD card.
I should be able to just take the OpenHabian image and use etcher to write it to a USB drive, right?
I’m having issue with the USB boot though. It seems the USB boot support is hit and miss. Those who are using a similar setup, what USB drive device are you using? I’d like to get the exact same thing as you.
If using USB drive, which drive?
If using USB-SATA adapter + SSD, which adapter are you using? Should any SATA SSD/HDD work in this situation?
Are any of you still using a microSD card to boot into the USB mass storage drive? If so, how did you setup the microSD card?
just wanted to communicate my experience with booting from USB attached SSD.
Purchased a SanDisk SSD Plus 2.5" 120GB
Purchased a Sabrent EC-UASP SATA to USB 3.0 Tool-Free External Hard Drive Enclosure
Followed the instructions to change RPi 3 to enable booting from USB (without SD card installed)
Installed latest Openhabian using Etcher onto SSD (using iMAC)
Tried to boot RPi 3 => no success
Played around for days to figure out why, read tons of messages…
Purchased another Enclosure for SSD: Inland IL2561-U2 (USB2 compatible)
Again used Etcher to put Openhabian onto SSD (using new Enclosure now)
=> Success, my RPi 3 is now in the process of booting and installing Openhabian (no SD card installed, only USB SSD connected).
So in summary, my winning combination was:
RPi 3
Inland IL2561-U2 enclosure
I assume that the Sabrent enclosure with its USB3 interface might have been the problem
I’m all new to OpenHAB and Rpi, and I also would like to boot my Rpi 3B+ from my 30GB USB stick without SD.
I found out that Raspbian is able to do that, but since I have no experience in OpenHAB and Linux, I would have no idea what I’m doing
So since I would like to use the “hassle-free installer” of OpenHABian, and I also had a try of the option “move to USB” in OpenHABian config, I found the stuff in the picture attached. My question is: Is it possible to tick that option [BOOT] marked with red square somehow?
(Also tried:
dd in VMware Ubuntu with gparted [SD is just 16GB, had to expand for USB],
and
writing OpenHABian image with Etcher to USB [install fails]
both without any success.)
I have only a USB flashdrive with 30GB, it is not a SSD. But direct flash and install from that doesn’t succeed… install exits every time with some failure between a few minutes-2hours period.
