I am using Rpi3 with openhab2
I connected the Rpi to wifi in my office and everything is OK. Now I am at home and want to connect my Rpi to the internet, I tried to connect it with an ethernet cable but it is not connected. Then I did these steps:-
Open the file openhabian.conf in a text editor
Uncomment and fill in wifi_ssid=“My Wi-Fi SSID” and wifi_psk=“password123”
Then edit the file to look like this… keep the parts that are already there, just edit the ‘network={}’ section…
network={
ssid="[ your router ssid ]"
psk="[ your router wifi pw ]"
scan_ssid=1
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
group=CCMP
auth_alg=OPEN
priority=1
id_str="[ name of your pi ]"
This will actually work for hidden networks as well.
