I installed OH2 with the rpi disk image. I can access the rpi through the web browser on port8080.
I can connect through ssh . But I am unable to login using openhab/habopen or pi/raspberry.
I am stumped on how to login to ssh.
If you used the openhabian image user and password are openhabian/openhabian.
Success! Thank you
Sorry to ask again but openhabian/openhabian does not work for me.
The system says:
Raspian GNU/Linux 8 openHABianPi tty
openHABianPi login:
When I enter “openhabian” as login and “openhabian” as pwd it says “Login failed”…
I just finished the autoinstallation and did nothing more. So what could the correct login be?
Ciao
Uwe
Sorry, but no: neither openhabian:openhabian nor openhab:habopen works.
So how can I reset a password if I cant login?! I’m just sitting in front of a monitor (connected to the Raspi) saying “Login incorrect”…
Ouch, sorry the answer was samba related.
First a side note. Do not use the RPi on your monitor. It’s supposed to run as a dedicated headless client. Remote Controlling it via SSH gives you many benefits.
The openHABian system login on a Raspberry Pi is either openhabian:openhabian on a v1.1 installation or pi:raspberry on an older build. If you are in fact on an older build, be aware that you might need to type a z
instead of the y
, depending on your keyboard (this doesn’t happen via SSH).
Tom, thanx a lot. Meanwhile I downloaded v1.1. and am installing right now. Let’s see if everything works.
Yes, I do agree: it is supposed to work headless. But: it’s always good to know what the actual credentials are
Ciao
Uwe
