I’m facing strange issues with my openhabian Installation.
First of all i tried The WiFi based installation where you edit the settings in the openhabian.conf file according to your WiFi.
Didn’t work.
After that I tried installation with Ethernet. This worked out in the third trial.
Now I’d like to get my openhabian to use WiFi. Without success. I tried the WiFi settings option in the openhabian-config, it tells !e that setting was successful and that I should reboot but after reboot the RPi3 is not connecting to my WiFi. Hardware itself must be fine because it was running libreelec on WiFi only with no issues until last week…
Anybody can give me a hint how to get the WiFi working?
Well. Ok.
Since I was not just sitting there waiting for help I did do the following:
I reflashed the sd with raspbian in order to go the way of manual installation.
So I booted raspbian and tried to connect WiFi there. Didn’t work. It listed my SSID but when I entered my password it was just like ignoring this. It just didn’t do anything.
And I tried a couple of times…
Since my router is giving the opportunity of having a separate guest network I just tried this one and it did work like a charm. Immediately connected.
So now I really wonder what’s going on here. The passwords are similar in format and content, the SSID of the guest network has the same name as the master network just followed by “_guest”…
Just raspbian and openhabian totally ignoring one of them while libreelec is using it without any issues…
